Time of Day Call Fowarding
eric.becker
I'm trying to configure a group of directory numbers(8) to forward based upon the following scenario.
8:00am - 5:00pm - Foward to the individuals voice mail after 20 seconds
5:00pm - 8:00pm - Foward to directory number #### after 20 seconds
8:00pm - 8:00am - Foward to the individuals voice mail.
Is there an easy way within CUCM (8.5) or Unity Connection (8.5) to do this? Thanks in advance for your help.
Jaime Valencia
I haven't tried this with 3 partitions but TOD should do the trick, since it will hide the partitions from the CSS if they're not in the active schedule you just configure the 3 partitions and set the time each one will be active and configure the routing as desired.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
