06-07-2016 03:18 AM - edited 03-18-2019 12:00 PM
Hello all ,
My company get a Toll Free Number from the teleco and we need to configure that so What is the steps of configuring it on cucm version 9.x ?
Solved! Go to Solution.
06-07-2016 06:04 AM
This is going to be very similar to other GW configs, most usually the telco will simply translate the toll free into a DN that is delivered to you, and then you simply choose how to route it within your system.
06-12-2016 11:53 AM
Yes, for you, it should be no different than receiving a DID, just configure whatever routing you want for it.
06-07-2016 04:10 AM
Configuration depends on how do you want to use that toll free number and when anyone calls that no. from outside, where the call should land.
Rajan
06-07-2016 06:04 AM
06-12-2016 12:16 AM
So All I need is to create a translation pattern for this toll free number to route the call to the phone inside the cluster. Am I get it right ?
06-12-2016 11:53 AM
