Transcoder doesn't work
3dtgnt_ljm
Hi All,
I have a center site with CUCM 5.1 in HQ office , there has a remote site via lease line connect to HQ office , either HQ or remote have 2800 router with PVDM2 as the local PSTN gateway . now remote site ip phones using G729 communication with HQ , but remote site cannot access like software conference and CUE that in HQ , I know it need XCODE in HQ , but it seemed that the transcode doesn't work . I want know how can I do ?
I have finished below:
1. put HQ device in hq-region and hq-device pool
2. put remote device in remote-region and remote-device pool
3. config the transcode in hq voice gateway and had registered to CUCM.
4. I even setup a individual region and device pool for XCODE.
but when I input "show dspfarm all " in voice gateway when I want jion a MeetMe or voice mail pilot number , I see there no any transcode be used . if there has any misunderstanding ? please tell me why ?
7 Replies 7
Chris Deren
Did you put this xcoder into MRG/MRGL that is referenced by HQ the conference bridge?
What does "debug sccp" reveal?
Chris
Hi Chris,
I think I have put xcoder int MRG/MRGL , below is my design
BeiJing is HQ site
XiAn is remote site
because BeiJing often take conference meeting more than 8 part, so I want use software conference that only support G711.
Is there anybody can help me ? I really dont know where I made mistake.
Does the Xcoder show refistered on CUCM?
Can you provide "sh dspfarm all"  from the BeiJing GW?
When attemting the conference call can you run "debug sccp" and provide the output?
Chris
Hi Chris,
Yesterday I delete the HW conference configuration in BeiJing Voicegateway, only left transcoder.
===============  show dspfarm all ============================
vg1.bj#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 6
Number of Resource Available : 6
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729r8, Maximum Packetization Period : 60
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Codec : g729br8, Maximum Packetization Period : 60
SLOT DSP VERSION  STATUS CHNL USE   TYPE   RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    1   8.4.1    UP     N/A  FREE  xcode  1      -         -         -
Total number of DSPFARM DSP channel(s) 6
vg1.bj#
I created a MeetMe using HQ phone, and used a remote phone dial the MeetMe number, below is the information of "debug sccp errors"
****************************** debug sccp errors ************************************
vg1.bj#debug sccp errors
Skinny Client Control Protocol errors debugging is on
vg1.bj#
Dec 30 2011 09:00:09: sym_xapp_find_peer_conn_cb: conn_cb->sess_cb is NULL
Dec 30 2011 09:00:09: sym_xapp_search_for_conn_cb: sess_id is ZERO to conn_cbconn_id 16928058
Dec 30 2011 09:00:09: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
Dec 30 2011 09:00:09: sym_xapp_xlate_ccapi_eve: Bridge request failed - bridge_id 23865, cause -5
Dec 30 2011 09:00:09: sym_xapp_close_receive_chnl: conn_cb not found for sess_id 16781492, conn_id 16928059 vg1.bj#debug sccp errors
vg1.bj#
Hi ,
I finally resolved this case, for help others , I show what I did .
1.  create a region for transcoder.
2.  create a device pool for transcoder
3.  change the codec between HQ and transcoder-region as g711, remote and transcoder-region as g729
4.  create the transcoder in voice gateway and register to CUCM
5.  put the transcoder resource into transcoder-device pool.
6.  use remote phone dial meetme or CUE number, show dspfarm all in voice gateway check if there havs session running.
Thanks Chris for your reply .
What exact meaning of "NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1."
000421: Sep 21 08:08:31.885 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000422: Sep 21 08:35:54.400 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000423: Sep 21 08:38:32.215 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000424: Sep 21 08:40:53.870 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000425: Sep 21 08:45:54.455 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000426: Sep 21 08:51:03.501 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000427: Sep 21 09:10:56.047 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000428: Sep 21 09:35:56.367 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000429: Sep 21 22:22:26.989 UTC: %SYS-5-CONFIG_I: Configured from 172.18.33.33 by snmp
000430: Sep 22 07:35:57.981 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000431: Sep 22 22:21:15.217 UTC: %SYS-5-CONFIG_I: Configured from 172.18.33.33 by snmp
000432: Sep 23 22:24:07.097 UTC: %SYS-5-CONFIG_I: Configured from 172.18.33.33 by snmp
000433: Sep 24 22:20:40.286 UTC: %SYS-5-CONFIG_I: Configured from 172.18.33.33 by snmp
000434: Sep 25 22:25:51.317 UTC: %SYS-5-CONFIG_I: Configured from 172.18.33.33 by snmp
000435: Sep 26 22:23:01.093 UTC: %SYS-5-CONFIG_I: Configured from 172.18.33.33 by snmp
000436: Sep 27 22:21:05.975 UTC: %SYS-5-CONFIG_I: Configured from 172.18.33.33 by snmp
000437: Sep 28 13:35:52.191 UTC: %C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 0 dsp 1.
000438: Sep 28 14:47:37.207 UTC: SSH2 0:  Invalid modulus length
000439: Sep 28 22:21:53.828 UTC: %SYS-5-CONFIG_I: Configured from 172.18.33.33 by snmp
