06-06-2017 02:11 AM - edited 03-17-2019 10:31 AM
Hallo,
Solved! Go to Solution.
06-06-2017 02:17 AM
Hi Pius,
There is not such migration process, you will have to send an email to licensing@cisco.com and they will have to migrate the licenses for you.
(Rate if it helps)
JB
06-06-2017 02:17 AM
Hi Pius,
(Rate if it helps)
JB
06-06-2017 02:24 AM
Hi Pius,
You could also add both CUCM clusters as a product instance in the same ELM/PLM if feasible and share the licenses.
Rajan
Pls rate all useful posts
