Transform a "NIM-PVDM-32=" into a "NIM-PVDM-128"
raziel1978kain
we have a "NIM-PVDM-32=" and a "PVDM4-128=".
We would like to know if, by replacing the "PVDM4-32" mounted on the "NIM-PVDM-32=" with the "PVDM4-128=", we can "transform" it into a "NIM-PVDM-128".
The idea is to avoid to buy a new "NIM-PVDM-128=".
TIA and regards.
As long as you can swap out the DSP module that should work. AFAIK there is nothing that is different on the NIM level between a NIM-PVDM-32 or a NIM-PVDM-128, they just have different PVDM DSP module on them.
Response Signature
Hello @Roger Kallberg,
thank you for the information.
We have another question: what about mounting the "PVDM4-128=" above on a TDM module (e.g., a "NIM-1MFT-T1/E1="), but using then all the DSPs for transcoding, conferencing, etc., and not for TDM termination? Is it possible?
Regards.
