07-11-2016 02:06 PM - edited 03-17-2019 07:29 AM
Hello Community,
I have recently installed a CUCM v11 on which I have registered a couple of SCCP phones (7960,7965,7975). Upon that, I have work on LDAP integration to provide Corporate Directory feature on the phone.
Since the LDAP info was on the form for example +44.1895.XXXX , I have created a translation Pattern so that when a user is trying to reach a corporate number via the CorpDirectory the translation pattern "strips" the dialled number (predot) to call only the last 4 digits (internal phone)
However this translation-pattern seems not to be working on a brand new SIP phone 8845, even though this phone is able to place internal/external calls.
Can someone help on the above?
thanks in advance,
George
07-12-2016 11:33 AM
Hi ,
You translation pattern CSS should have access to the 4 digit internal partition.
Also can you paste the config for translation-pattern ?
07-13-2016 01:41 AM
Are other SCCP/SIP phones working fine - I mean are they able to use the same translation pattern?
What's the exact behavior with 8845 phone?
and yes we need more details about the TP as deepak mentioned.
-Atul
07-13-2016 04:54 AM
Thank you both for replying on this, the translation pattern that was working on the SCCP phones was at the form 44.1895.XXXX.
In order to solve this, I managed to create one new translation pattern that had the form
\+44.1895.XXXX
So this solved the case...
Thanks again,
george
