Translation-rule for cisco 5350
zhelikhov
Good afternoon.
Tell me how to change the rule to cisco 5350 Version 12.2 (2) XB6 or where you can read about the translation-rules for this equipment.
Translation - rule for Cisco 2620 :
C2600 Software (C2600-IS3X-M), Version 12.3(26)
voice translation-rule 55
rule 1 /^55\(.*\)/ /\1/
But on cisco 5350 Version 12.2 (2) XB6 these rule can not be created.
Why ?
6 Replies 6
ronpatel
Level 8
Level 8
HI
This commands were introduced in 2.2(11)T  and you are running old IOS. Please upgrade to latest IOS and you will be able to configure it.
Ronak patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Thank you for your help.
I have now established that:
ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1)
BOOTLDR: 5350 Software (C5350-BOOT-M), Version 12.2(2)XB2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
System image file is "flash:c5350-is-mz.122-2.XB6.bin"
512K bytes of non-volatile configuration memory.
65536K bytes of processor board System flash (Read/Write)
16384K bytes of processor board Boot flash (Read/Write)
What do I need from the new ios?
Go to Cisco.com download and select your product and download latest IOS for your router AS 5350.
Go to following link
http://www.cisco.com/en/US/products/hw/univgate/ps501/ps503/index.html
Right side, Click Download Software for this product. Select IOS software and download the latest IOS software.
Any IOS image after 12.2(11)T wll have the feature.
Ronak patel
c5350-is-mz.123-26.bin  - supports voip ?
Yes. It supports VOIP.
You can also check it using Cisco feature navigator tool.
regards
Ronak patel
rate all helpful posts by clikcing stars below the answer.
Thank you.
