Trouble with Caller ID on SPA 8800 in Mexico
Hi all,
I'm facing an issue with my SPA 8800 (Firmware: 6.1.11(XU)) configuration in Mexico. I'm attempting to utilize one FXO port and direct all calls to a SIP trunk.
Here's my Dial Plan 8: (<:2010@192.168.5.2>S0)
The ATA is located in Mexico, connected to Telnor/Telmex, which transports voice/data over fiber and terminates at the customer with a modem converting SIP calls to analog. When I connect an analog phone to the modem's phone line port, I consistently receive caller ID. However, when I connect the Cisco SPA 8800 to the modem, caller ID rarely functions. Despite caller ID service is enabled and conducting tests with a known working phone, caller ID works only sporadically.
I've spent four days troubleshooting, and caller ID has only worked twice during this time. I managed to capture debug logs during these rare instances and would greatly appreciate assistance from someone with the expertise to interpret them and suggest any necessary settings adjustments to ensure consistent caller ID reception on the SPA 8800.
Considering the Mexico location, I've configured the following regional settings:
Tone Information (source: World Tone Database
  • Busy tone: 425 Hz, 0.25 on 0.25 off
  • Congestion tone: 425 Hz, 0.25 on 0.25 off
  • Dial tone: 425 Hz, continuous
  • Disconnect tone: [No information available]
For visibility, I've replaced the actual caller ID with 17601234567 in the debug logs below.
Logs when caller ID doesn't work (about 99% of the time):
Apr 28 16:23:58 192.168.5.5 M0: ++++++++ fxo: get sesssion = 3ffbe4; cst=0
Apr 28 16:23:58 192.168.5.5 M0: ++++++++ fxo state= ;0;2;;;1;;;1;4;45a97ba0-9f311686@192.168.5.5;192.168.5.2:5060;
Apr 28 16:23:58 192.168.5.5 M0: @@@@@@@@ peer phone=, len=62
Apr 28 16:23:58 192.168.5.5 M0: FXO:Start CNDD
Apr 28 16:24:00 192.168.5.5 M0: +++ send lvs discovery
Apr 28 16:24:00 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:24:00 192.168.5.5 M0: Sess Terminated
Apr 28 16:24:02 192.168.5.5 M0: AUD:Stop PSTN Tone
Apr 28 16:24:02 192.168.5.5 M0: Calling:2010@192.168.5.2:0
Apr 28 16:24:02 192.168.5.5 M0: ++++ called number = 2010
Apr 28 16:24:02 192.168.5.5 M0: [1:0]AUD ALLOC CALL (port=16441)
Apr 28 16:24:02 192.168.5.5 M0: [1:0]RTP Rx Up
Apr 28 16:24:03 192.168.5.5 M0: SDP RTPMAP 101 --> 136
Apr 28 16:24:03 192.168.5.5 M0: [1:0]ENC INIT 0
Apr 28 16:24:03 192.168.5.5 M0: [1:0]RTP Tx Up (pt=0->c0a80502:13928)
Apr 28 16:24:03 192.168.5.5 M0: [1:0]RTCP Tx Up
Apr 28 16:24:03 192.168.5.5 M0: CC:Remote Resume
Apr 28 16:24:03 192.168.5.5 M0: AUD:Stop PSTN Tone
Apr 28 16:24:03 192.168.5.5 M0: CC:Connected
Apr 28 16:24:03 192.168.5.5 M0: ==== fxo_line_check: line 1, state 0 -> 1
Apr 28 16:24:03 192.168.5.5 M0: FXO:Off Hook
Apr 28 16:24:03 192.168.5.5 M0: FXO:Stop CNDD
Apr 28 16:24:03 192.168.5.5 M0: ++++++++ fxo: get sesssion = 4021ec; cst=8
Apr 28 16:24:03 192.168.5.5 M0: ++++++++ fxo state= ;0;1;2010@192.168.5.2;;0;;;1;3;82428d84-d569b4c@192.168.5.5;192.168.5.2:5060;
Apr 28 16:24:03 192.168.5.5 M0: @@@@@@@@ peer phone=, len=77
Apr 28 16:24:03 192.168.5.5 M0: [1:0]RTP Rx 1st PKT @16441(2)
Apr 28 16:24:03 192.168.5.5 M0: [1:0]DEC INIT 0
Apr 28 16:24:10 192.168.5.5 M0: +++ send lvs discovery
Apr 28 16:24:10 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:24:11 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:24:16 192.168.5.5 M0: ++++ retry query scaps
Apr 28 16:24:16 192.168.5.5 M0: +++ need tftp addr..
Apr 28 16:24:16 192.168.5.5 M0: +++ send scaps discovery query
Apr 28 16:24:16 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:24:17 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:24:18 192.168.5.5 M0: [1:0]LAT++ 7(2)
Apr 28 16:24:20 192.168.5.5 M0: +++ send lvs discovery
Apr 28 16:24:20 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:24:21 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:24:21 192.168.5.5 M0: FXO:PSTN Disconnect Tone
Apr 28 16:24:21 192.168.5.5 M0: AUD:Stop PSTN Tone
Apr 28 16:24:21 192.168.5.5 M0: ==== fxo_line_check: line 1, state 1 -> 0
Apr 28 16:24:21 192.168.5.5 M0: FXO:On Hook
Apr 28 16:24:21 192.168.5.5 M0: ++++++++ fxo: get sesssion = 4021ec; cst=0
Apr 28 16:24:21 192.168.5.5 M0: ++++++++ fxo state= ;0;0;;;1;;;1;3;82428d84-d569b4c@192.168.5.5;192.168.5.2:5060;
Apr 28 16:24:21 192.168.5.5 M0: @@@@@@@@ peer phone=, len=61
Apr 28 16:24:21 192.168.5.5 M0: [0]FM Alert Stop RxTx (c=003b46b0;a=0)
Apr 28 16:24:21 192.168.5.5 M0: [1:0]AUD Rel Call
Apr 28 16:24:21 192.168.5.5 M0: DLG Terminated 3ff6a8
Logs when caller ID works:
Apr 28 16:23:19 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:23:19 192.168.5.5 M0: POL REV 49 -49
Apr 28 16:23:19 192.168.5.5 M0: FXO:OnHook PolRev
Apr 28 16:23:19 192.168.5.5 M0: FXO:Start CNDD
Apr 28 16:23:19 192.168.5.5 M0: +++++ fxo report new state 1
Apr 28 16:23:19 192.168.5.5 M0: ++++++++ fxo: get sesssion = 0; cst=0
Apr 28 16:23:19 192.168.5.5 M0: ++++ fxo in use
Apr 28 16:23:19 192.168.5.5 M0: ++++++++ fxo state= ;0;4;;;1;;;;;;;
Apr 28 16:23:19 192.168.5.5 M0: @@@@@@@@ peer phone=, len=15
Apr 28 16:23:19 192.168.5.5 M0: +++++ fxo report new state 0
Apr 28 16:23:19 192.168.5.5 M0: ++++++++ fxo state= ;0;0;;;1;;;;;;;
Apr 28 16:23:19 192.168.5.5 M0: POL REV -20 81
Apr 28 16:23:19 192.168.5.5 M0: POL REV 22 -79
Apr 28 16:23:20 192.168.5.5 M0: +++++ fxo report new state 0
Apr 28 16:23:20 192.168.5.5 M0: ++++++++ fxo: get sesssion = 0; cst=0
Apr 28 16:23:20 192.168.5.5 M0: ++++++++ fxo state= ;0;0;;;1;;;;;;;
Apr 28 16:23:20 192.168.5.5 M0: @@@@@@@@ peer phone=, len=15
Apr 28 16:23:20 192.168.5.5 M0: POL REV -77 50
Apr 28 16:23:21 192.168.5.5 M0: caller id parse number=17601234567
Apr 28 16:23:21 192.168.5.5 M0: fxo cnddwrap_feed parse ok 17601234567 status=2
Apr 28 16:23:21 192.168.5.5 M0: -- Caller ID:#012-- Name = (null)#012-- Remote Number = 17601234567#012-- Dialable Number = (null)#012-- No Number Reason = (null)#012-- No Name Reason = (null)#012-- Message Waiting = (null)#012-- Date and Time = 04/28 18:23
Apr 28 16:23:21 192.168.5.5 M0: FXO:CNDD name=, number=17601234567
Apr 28 16:23:21 192.168.5.5 M0: FXO_modifyCallerId 3452 ([x*#][x*#].)
Apr 28 16:23:21 192.168.5.5 M0: FXO:Stop CNDD
Apr 28 16:23:21 192.168.5.5 M0: FXO:CNDD Name= Phone=17601234567
Apr 28 16:23:21 192.168.5.5 M0: ++++++++ fxo: get sesssion = 0; cst=0
Apr 28 16:23:21 192.168.5.5 M0: ++++++++ fxo state= ;0;0;;17601234567;1;;;;;;;
Apr 28 16:23:21 192.168.5.5 M0: @@@@@@@@ peer phone=17601234567, len=26
Apr 28 16:23:24 192.168.5.5 M0: ++++++++ fxo: get sesssion = 0; cst=0
Apr 28 16:23:24 192.168.5.5 M0: ++++++++ fxo state= ;0;2;;17601234567;1;;;;;;;
Apr 28 16:23:24 192.168.5.5 M0: @@@@@@@@ peer phone=17601234567, len=26
Apr 28 16:23:24 192.168.5.5 M0: FXO:Start CNDD
Apr 28 16:23:28 192.168.5.5 M0: AUD:Stop PSTN Tone
Apr 28 16:23:28 192.168.5.5 M0: Calling:2010@192.168.5.2:0
Apr 28 16:23:28 192.168.5.5 M0: ++++ called number = 2010
Apr 28 16:23:28 192.168.5.5 M0: [1:0]AUD ALLOC CALL (port=16439)
Apr 28 16:23:28 192.168.5.5 M0: [1:0]RTP Rx Up
Apr 28 16:23:28 192.168.5.5 M0: SDP RTPMAP 101 --> 136
Apr 28 16:23:28 192.168.5.5 M0: [1:0]ENC INIT 0
Apr 28 16:23:28 192.168.5.5 M0: [1:0]RTP Tx Up (pt=0->c0a80502:17206)
Apr 28 16:23:28 192.168.5.5 M0: [1:0]RTCP Tx Up
Apr 28 16:23:28 192.168.5.5 M0: CC:Remote Resume
Apr 28 16:23:28 192.168.5.5 M0: CC:Connected
Apr 28 16:23:28 192.168.5.5 M0: ==== fxo_line_check: line 1, state 0 -> 1
Apr 28 16:23:28 192.168.5.5 M0: FXO:Off Hook
Apr 28 16:23:28 192.168.5.5 M0: FXO:Stop CNDD
Apr 28 16:23:28 192.168.5.5 M0: ++++++++ fxo: get sesssion = 3ffbe4; cst=8
Apr 28 16:23:28 192.168.5.5 M0: ++++++++ fxo state= ;0;1;;17601234567;0;;;1;3;45a97ba0-9f311686@192.168.5.5;192.168.5.2:5060;
Apr 28 16:23:28 192.168.5.5 M0: @@@@@@@@ peer phone=17601234567, len=73
Apr 28 16:23:28 192.168.5.5 M0: ++++++++ fxo state= ;0;1;2010@192.168.5.2;17601234567;0;;;1;3;45a97ba0-9f311686@192.168.5.5;192.168.5.2:5060;
Apr 28 16:23:28 192.168.5.5 M0: @@@@@@@@ peer phone=17601234567, len=89
Apr 28 16:23:28 192.168.5.5 M0: [1:0]RTP Rx 1st PKT @16439(2)
Apr 28 16:23:29 192.168.5.5 M0: [1:0]DEC INIT 0
Apr 28 16:23:29 192.168.5.5 M0: +++ send lvs discovery
Apr 28 16:23:29 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:23:30 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:23:30 192.168.5.5 M0: ++++ retry query scaps
Apr 28 16:23:30 192.168.5.5 M0: +++ need tftp addr..
Apr 28 16:23:30 192.168.5.5 M0: +++ send scaps discovery query
Apr 28 16:23:31 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:23:39 192.168.5.5 M0: +++ send lvs discovery
Apr 28 16:23:39 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:23:40 192.168.5.5 M0: @@@ scapc send to e0a8a8a8:6061
Apr 28 16:23:45 192.168.5.5 M0: [1:0]LAT-- 5(2)
Apr 28 16:23:45 192.168.5.5 M0: FXO:PSTN Disconnect Tone
Apr 28 16:23:45 192.168.5.5 M0: AUD:Stop PSTN Tone
Apr 28 16:23:45 192.168.5.5 M0: ==== fxo_line_check: line 1, state 1 -> 0
Apr 28 16:23:45 192.168.5.5 M0: FXO:On Hook
Apr 28 16:23:45 192.168.5.5 M0: ++++++++ fxo: get sesssion = 3ffbe4; cst=0
Apr 28 16:23:45 192.168.5.5 M0: ++++++++ fxo state= ;0;0;;;1;;;1;3;45a97ba0-9f311686@192.168.5.5;192.168.5.2:5060;
Apr 28 16:23:45 192.168.5.5 M0: @@@@@@@@ peer phone=, len=62
Apr 28 16:23:45 192.168.5.5 M0: [0]FM Alert Stop RxTx (c=003b46b0;a=0)
Apr 28 16:23:45 192.168.5.5 M0: [1:0]AUD Rel Call
Apr 28 16:23:45 192.168.5.5 M0: DLG Terminated 3ff614
Maybe some of these settings need to be modified to make caller id works? (I am not sure)
Since this is located in Mexico I choose the following regional settings:
I'm hoping someone can help me diagnose and resolve this issue. Any insights or suggestions would be greatly appreciated. Thanks in advance!
Nobody reply me anything.
Issue solved after repalcing the cisco spa with a yeastar fxo gateway.
