Debug output is below. I'm matching dial-peer 3001 which is what I would expect (incoming called-number taking priority over destination-pattern). I posted the new ISR config in a previous post.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2010.10.05 10:20:33 =~=~=~=~=~=~=~=~=~=~=~=
sh logg
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 504 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
Trap logging: level informational, 58 message lines logged
Log Buffer (10000000 bytes):
000054: Oct 5 10:18:52.683: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_PERIODIC_RRQ_TIMER] expired
000055: Oct 5 10:18:52.683: //-1/xxxxxxxxxxxx/H323/cch323_send_event_to_ras: Queued event CCH323_RAS_EVENT_SEND_LT_RRQ to RAS Global SM
000056: Oct 5 10:18:52.683: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0xA internal event to RAS Global SM
000057: Oct 5 10:18:52.683: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: received event CCH323_RAS_EVENT_SEND_LT_RRQ while at CCH323_RAS_STATE_IDLE state
000058: Oct 5 10:18:52.683: RAS OUTGOING PDU ::=
value RasMessage ::= registrationRequest :
requestSeqNum 1262
protocolIdentifier { 0 0 8 2250 0 4 }
discoveryComplete TRUE
callSignalAddress
rasAddress
ipAddress :
ip '06060607'H
port 63383
terminalType
mc FALSE
undefinedNode FALSE
gatekeeperIdentifier {"ZONE_01"}
endpointVendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
timeToLive 60
keepAlive TRUE
endpointIdentifier {"672C9F6C00000001"}
willSupplyUUIEs FALSE
maintainConnection TRUE
000059: Oct 5 10:18:52.687: RAS OUTGOING ENCODE BUFFER::= 0E4004ED060008914A00048000010006060607F7970006005A004F004E0045005F0030003100B5000012288F000002003B0180211E003600370032004300390046003600430030003000300030003000300030003101000180
000060: Oct 5 10:18:52.687:
000061: Oct 5 10:18:52.687: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: changing to CCH323_RAS_STATE_RRQ state
000062: Oct 5 10:18:52.751: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
000063: Oct 5 10:18:52.751: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x49D57F60, len=70, msgPtr=0x49D566E8
000064: Oct 5 10:18:52.751: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for RAS
000065: Oct 5 10:18:52.751: RAS INCOMING ENCODE BUFFER::= 124004ED060008914A0004000C005A004F004E0045005F003000311E0036003700320043003900460036004300300030003000300030003000300031208A0002003B01000180
000066: Oct 5 10:18:52.751:
000067: Oct 5 10:18:52.751: RAS INCOMING PDU ::=
value RasMessage ::= registrationConfirm :
requestSeqNum 1262
callSignalAddress
timeToLive 60
willRespondToIRR FALSE
000068: Oct 5 10:18:52.755: //-1/xxxxxxxxxxxx/H323/cch323_ras_handle_recv_msg: received msg of type RCF_CHOSEN
000069: Oct 5 10:18:52.755: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: received event CCH323_RAS_EVENT_RCF while at CCH323_RAS_STATE_RRQ state
000070: Oct 5 10:18:52.755: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: changing to CCH323_RAS_STATE_IDLE state
000071: Oct 5 10:19:37.755: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_PERIODIC_RRQ_TIMER] expired
000072: Oct 5 10:19:37.755: //-1/xxxxxxxxxxxx/H323/cch323_send_event_to_ras: Queued event CCH323_RAS_EVENT_SEND_LT_RRQ to RAS Global SM
000073: Oct 5 10:19:37.755: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0xA internal event to RAS Global SM
000074: Oct 5 10:19:37.755: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: received event CCH323_RAS_EVENT_SEND_LT_RRQ while at CCH323_RAS_STATE_IDLE state
000075: Oct 5 10:19:37.755: RAS OUTGOING PDU ::=
requestSeqNum 1263
callSignalAddress
rasAddress
ipAddress :
ip '06060607'H
port 63383
terminalType
mc FALSE
undefinedNode FALSE
endpointVendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
timeToLive 60
keepAlive TRUE
000076: Oct 5 10:19:37.759: RAS OUTGOING ENCODE BUFFER::= 0E4004EE060008914A00048000010006060607F7970006005A004F004E0045005F0030003100B5000012288F000002003B0180211E003600370032004300390046003600430030003000300030003000300030003101000180
000077: Oct 5 10:19:37.759:
000078: Oct 5 10:19:37.759: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: changing to CCH323_RAS_STATE_RRQ state
000079: Oct 5 10:19:37.819: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
000080: Oct 5 10:19:37.819: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x49D57F60, len=70, msgPtr=0x49D568B8
000081: Oct 5 10:19:37.819: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for RAS
000082: Oct 5 10:19:37.819: RAS INCOMING ENCODE BUFFER::= 124004EE060008914A0004000C005A004F004E0045005F003000311E0036003700320043003900460036004300300030003000300030003000300031208A0002003B01000180
000083: Oct 5 10:19:37.819:
000084: Oct 5 10:19:37.819: RAS INCOMING PDU ::=
requestSeqNum 1263
callSignalAddress
timeToLive 60
000085: Oct 5 10:19:37.819: //-1/xxxxxxxxxxxx/H323/cch323_ras_handle_recv_msg: received msg of type RCF_CHOSEN
000086: Oct 5 10:19:37.819: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: received event CCH323_RAS_EVENT_RCF while at CCH323_RAS_STATE_RRQ state
000087: Oct 5 10:19:37.819: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: changing to CCH323_RAS_STATE_IDLE state
000088: Oct 5 10:19:56.112: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:3001@6.6.6.7:5060 SIP/2.0
Date: Tue, 05 Oct 2010 14:19:55 GMT
Call-Info: <10.1.200.20:5060>;method="NOTIFY;Event=telephone-event;Duration=500"10.1.200.20:5060>
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <1001>;tag=672f0396-d595-4a92-b33d-446800d37753-277724971001>
Allow-Events: presence, kpml
P-Asserted-Identity: <1001>1001>
Supported: timer,resource-priority,replaces
Supported: Geolocation
Min-SE: 1800
Remote-Party-ID: <1001>;party=calling;screen=yes;privacy=off1001>
Content-Length: 0
User-Agent: Cisco-CUCM7.1
To: <3001>3001>
Contact: <1001>1001>
Expires: 180
Call-ID: 9ee9bd00-cab1340b-1d-14c8010a@10.1.200.20
Via: SIP/2.0/TCP 10.1.200.20:5060;branch=z9hG4bK2423dd8b96
CSeq: 101 INVITE
Session-Expires: 1800
Max-Forwards: 70
000089: Oct 5 10:19:56.120: //-1/7661A559800A/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=1001
----- ccCallInfo IE subfields -----
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=3001
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
000090: Oct 5 10:19:56.124: //-1/7661A559800A/CCAPI/cc_api_call_setup_ind_common:
Interface=0x4705BD7C, Call Info(
Calling Number=1001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=3001(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=3001, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=9
000091: Oct 5 10:19:56.124: //-1/7661A559800A/CCAPI/ccCheckClipClir:
In: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
000092: Oct 5 10:19:56.124: //-1/7661A559800A/CCAPI/ccCheckClipClir:
Out: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
000093: Oct 5 10:19:56.124: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000094: Oct 5 10:19:56.124: :cc_get_feature_vsa malloc success
000095: Oct 5 10:19:56.124: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000096: Oct 5 10:19:56.124: cc_get_feature_vsa count is 1
000097: Oct 5 10:19:56.124: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000098: Oct 5 10:19:56.124: :FEATURE_VSA attributes are: feature_name:0,feature_time:1239945304,feature_id:9
000099: Oct 5 10:19:56.124: //9/7661A559800A/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=3001(TON=Unknown, NPI=Unknown))
000100: Oct 5 10:19:56.128: //9/7661A559800A/CCAPI/cc_process_call_setup_ind:
Event=0x472D5190
000101: Oct 5 10:19:56.128: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 3001
000102: Oct 5 10:19:56.132: //9/7661A559800A/CCAPI/ccCallSetContext:
Context=0x464789A4
000103: Oct 5 10:19:56.132: //9/7661A559800A/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 9 with tag 3001 to app "_ManagedAppProcess_Default"
000104: Oct 5 10:19:56.132: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <3001>3001>
Date: Tue, 05 Oct 2010 14:19:56 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
000105: Oct 5 10:19:56.136: //9/7661A559800A/CCAPI/ccCallProceeding:
000106: Oct 5 10:19:56.136: //9/7661A559800A/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=3000, Params=0x46479CFC, Progress Indication=NULL(0)
000107: Oct 5 10:19:56.140: //9/7661A559800A/CCAPI/ccCheckClipClir:
000108: Oct 5 10:19:56.140: //9/7661A559800A/CCAPI/ccCheckClipClir:
000109: Oct 5 10:19:56.140: //9/7661A559800A/CCAPI/ccCallSetupRequest:
Destination Pattern=3..., Called Number=3001, Digit Strip=FALSE
000110: Oct 5 10:19:56.140: //9/7661A559800A/CCAPI/ccCallSetupRequest:
Redirect Number=, Display Info=
Account Number=1001, Final Destination Flag=TRUE,
Guid=7661A559-CFC2-11DF-800A-B8130721089B, Outgoing Dial-peer=3000
000111: Oct 5 10:19:56.140: //9/7661A559800A/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=1001
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=3001
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
000112: Oct 5 10:19:56.140: //9/7661A559800A/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x478B1418, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=1001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=3001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3000, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
000113: Oct 5 10:19:56.140: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000114: Oct 5 10:19:56.140: :cc_get_feature_vsa malloc success
000115: Oct 5 10:19:56.140: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000116: Oct 5 10:19:56.140: cc_get_feature_vsa count is 2
000117: Oct 5 10:19:56.140: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000118: Oct 5 10:19:56.140: :FEATURE_VSA attributes are: feature_name:0,feature_time:1239945080,feature_id:10
000119: Oct 5 10:19:56.140: //-1/xxxxxxxxxxxx/H323/cch323_post_call_setup_request: callID=10
000120: Oct 5 10:19:56.140: //-1/xxxxxxxxxxxx/H323/cch323_post_call_setup_request: incoming_call=0 incoming_media=0
000121: Oct 5 10:19:56.140: //-1/xxxxxxxxxxxx/H323/cch323_post_call_setup_request: incoming_call=0 incoming_media=0
000122: Oct 5 10:19:56.140: //10/7661A559800A/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
000123: Oct 5 10:19:56.144: //10/7661A559800A/CCAPI/ccCallSetContext:
Context=0x46479CAC
000124: Oct 5 10:19:56.144: //9/7661A559800A/CCAPI/ccSaveDialpeerTag:
000125: Oct 5 10:19:56.144: //-1/xxxxxxxxxxxx/H323/cch323_get_new_ccb: ccb (0x49F6FE00) is in use
000126: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_call_setup: gw_id=1
000127: Oct 5 10:19:56.144: //-1/xxxxxxxxxxxx/H323/h323_TD_get_mlpp_info: callID=10, tag=(CC_TAG_MLPP_INFO), Failed AV get
000128: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_call_setup: Inserted ccb
000129: Oct 5 10:19:56.144: //-1/xxxxxxxxxxxx/H323/cch323_create_call_info_type_container:
cch323_create_call_info_type_container: creating callInfoType container for callID = 10
000130: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_set_h245_state_mc_mode_outgoing: call_spi_mode = 3
000131: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_set_h245_state_mc_mode_outgoing: h245 state m/c mode=0x4F0, h323_ctl=0x0
000132: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_get_peer_info: Entry
000133: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_get_peer_info: Have peer
000134: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_get_peer_info: faxrate[45] proto[3] bitmask[10082] t38_inhibit[0] global_fax[0] t38fax[0]
000135: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_set_pref_codec_list: First preferred codec(bytes)=16(20)
000136: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_get_peer_info: Preferred codec set to G729IETF with Bytes = 20
000137: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_get_peer_info: Flow Mode set to FLOW_THROUGH
000138: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_get_peer_info: peer: 48B19904, peer->voice_peer_tag: BB8, ccb: 49F6FE00
000139: Oct 5 10:19:56.144: //10/7661A559800A/H323/cch323_set_h323_parms_from_dp: ccb h245addr bits = system[0x0007]
000140: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_set_h323_parms_from_dp: ccb ccm bits = system[0x0028]
000141: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_update_setup_callinfo: callingNumber = 1001
000142: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_update_setup_callinfo: called_oct3 = 0x0, calling_oct3 = 0x0, calling_oct3a = 0x81
000143: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_set_h323_control_options_outgoing: h245 sm mode = 1264
000144: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_set_h323_control_options_outgoing: h323_ctl=0x20
000145: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_call_setup: No account/pin number available
000146: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_store_call_info: Call_setup Playout Mode: 1,Init 60, Min 40, Max 1000, Fax 300
000147: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_call_setup_normal: Entry
000148: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_call_setup_normal: SETUP_NTF_TIMER is not running. Continue processing.
000149: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_IDLE state
000150: Oct 5 10:19:56.148: //10/7661A559800A/H323/cch323_store_call_info: Call_setup Playout Mode: 1,Init 60, Min 40, Max 1000, Fax 300
000151: Oct 5 10:19:56.212: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 3 Event 0x1
000152: Oct 5 10:19:56.212: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0xB internal event to H225 SM
000153: Oct 5 10:19:56.212: //10/7661A559800A/H323/run_h225_sm: Received event H225_EV_SETUP while at state H225_IDLE
000154: Oct 5 10:19:56.212: //10/7661A559800A/H323/check_qos_and_send_setup: Setup ccb 0x49F6FE00
000155: Oct 5 10:19:56.212: //10/7661A559800A/H323/cch323_rotary_validate: No peer_ccb available
000156: Oct 5 10:19:56.212: //10/7661A559800A/H323/send_setup: Entry
000157: Oct 5 10:19:56.212: //10/7661A559800A/H323/generic_send_setup: Entry
000158: Oct 5 10:19:56.212: //10/7661A559800A/H323/copy_token_from_ccb: copy_token_from_ccb: Entered
000159: Oct 5 10:19:56.212: //10/7661A559800A/H323/generic_send_setup:
generic_send_setup: is_overlap = 0, info_complete = 0
000160: Oct 5 10:19:56.212: //10/7661A559800A/H323/generic_send_setup: sending calling IE
000161: Oct 5 10:19:56.212: //10/7661A559800A/H323/cch323_get_embedded_obj_from_ccb: ccb=0x49F6FE00, tag=24, size=88
000162: Oct 5 10:19:56.212: //10/7661A559800A/H323/cch323_get_embedded_obj_from_ccb: Extraction FAILED
000163: Oct 5 10:19:56.212: //10/7661A559800A/H323/generic_send_setup: ====== PI = 0
000164: Oct 5 10:19:56.212: //10/7661A559800A/H323/generic_send_setup: Send infoXCap=128, infoXRate=16, rateMult=0, xMode=128, info_layer1_prot=163
000165: Oct 5 10:19:56.212: //10/7661A559800A/H323/generic_send_setup: src address = 6.6.6.7; dest address = 3.3.3.3
000166: Oct 5 10:19:56.212: H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
h323-uu-pdu
h323-message-body setup :
sourceInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
productId '436973636F47617465776179'H
versionId '32'H
gateway
protocol
voice :
supportedPrefixes
}, h323 :
supportedPrefixes
mc FALSE
undefinedNode FALSE
activeMC FALSE
conferenceID '7661A559CFC211DF800AB8130721089B'H
conferenceGoal create : NULL
callType pointToPoint : NULL
sourceCallSignalAddress ipAddress :
ip '06060607'H
port 38972
callIdentifier
guid '7662DDA9CFC211DF800CB8130721089B'H
mediaWaitForConnect FALSE
canOverlapSend FALSE
multipleCalls TRUE
h245Tunneling FALSE
000167: Oct 5 10:19:56.220: H225.0 OUTGOING ENCODE BUFFER::= 2080060008914A000428C0B50000120B436973636F47617465776179003240023C0501002C050100007661A559CFC211DF800AB8130721089B00CD0D8000070006060607983C11007662DDA9CFC211DF800CB8130721089B010001000180018010800100
000168: Oct 5 10:19:56.220:
000169: Oct 5 10:19:56.224: //10/7661A559800A/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_SETUP state
000170: Oct 5 10:19:56.224: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 3 Event 0x1
000171: Oct 5 10:19:56.476: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 3 Event 0x1
000172: Oct 5 10:19:56.476: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x49D55E4C, len=68, msgPtr=0x49D8C710
000173: Oct 5 10:19:56.476: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
000174: Oct 5 10:19:56.476: H225.0 INCOMING ENCODE BUFFER::= 21C0060008914A00042800B500001240013C05040100204000030303038152110C11007662DDA9CFC211DF800CB8130721089B0180018010800100
000175: Oct 5 10:19:56.476:
000176: Oct 5 10:19:56.476: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body callProceeding :
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
prefix dialedDigits : "1#"
mc FALSE
undefinedNode FALSE
h245Address ipAddress :
ip '03030303'H
port 33106
callIdentifier
multipleCalls TRUE
h245Tunneling FALSE
000177: Oct 5 10:19:56.484: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type CALLPROCIND_CHOSEN
000178: Oct 5 10:19:56.484: //10/7661A559800A/H323/callproc_ind: Entry
000179: Oct 5 10:19:56.484: //10/7661A559800A/H323/callproc_ind: ====== PI = 0
000180: Oct 5 10:19:56.484: //10/7661A559800A/H323/cch323_h225_receiver: CALLPROCIND_CHOSEN: src address = 6.6.6.7; dest address = 3.3.3.3
000181: Oct 5 10:19:56.484: //10/7661A559800A/H323/run_h225_sm: Received event H225_EV_CALLPROC_IND while at state H225_SETUP
000182: Oct 5 10:19:56.484: //10/7661A559800A/H323/h245_address_ind: ev=0
000183: Oct 5 10:19:56.484: //10/7661A559800A/CCAPI/ccIsInfoRingback:
Returning dpRingBack=0
000184: Oct 5 10:19:56.484: //10/7661A559800A/H323/callproc_notify: Peer not ready so not starting TCP
000185: Oct 5 10:19:56.484: //10/7661A559800A/H323/generic_callproc_notify: Entry
000186: Oct 5 10:19:56.484: //10/7661A559800A/CCAPI/cc_api_call_proceeding:
Interface=0x478B1418, Progress Indication=NULL(0)
000187: Oct 5 10:19:56.484: //10/7661A559800A/H323/cch323_h225_set_new_state: Changing from H225_SETUP state to H225_CALLPROC state
000188: Oct 5 10:19:56.836: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 3 Event 0x1
000189: Oct 5 10:19:56.836: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x49D55E4C, len=74, msgPtr=0x49D55C08
000190: Oct 5 10:19:56.836: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
000191: Oct 5 10:19:56.836: H225.0 INCOMING ENCODE BUFFER::= 23C0060008914A00042800B500001240013C050401002040000303030381521B0C0011007662DDA9CFC211DF800CB8130721089B0180018010800100
000192: Oct 5 10:19:56.836:
000193: Oct 5 10:19:56.836: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body alerting :
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
ip '03030303'H
port 33106
callIdentifier
multipleCalls TRUE
h245Tunneling FALSE
000194: Oct 5 10:19:56.840: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type ALERTIND_CHOSEN
000195: Oct 5 10:19:56.844: //10/7661A559800A/H323/alert_ind: ====== PI = 0
000196: Oct 5 10:19:56.844: //10/7661A559800A/H323/alert_ind: alert ind ie_bit_mask 0x5E60, displayInfo
000197: Oct 5 10:19:56.844: //10/7661A559800A/H323/alert_ind: Rcvd ALERT Display Info IE =
000198: Oct 5 10:19:56.844: //10/7661A559800A/H323/cch323_put_embedded_obj_to_ccb: ccb=0x49F6FE00, tag=17, size=83
000199: Oct 5 10:19:56.844: //10/7661A559800A/H323/cch323_put_embedded_obj_to_ccb: Insertion PASSED, embedded at 0x49F72638
000200: Oct 5 10:19:56.844: //10/7661A559800A/H323/cch323_h225_receiver: ALERTIND_CHOSEN: src address = 6.6.6.7; dest address = 3.3.3.3
000201: Oct 5 10:19:56.844: //10/7661A559800A/H323/run_h225_sm: Received event H225_EV_ALERT_IND while at state H225_CALLPROC
000202: Oct 5 10:19:56.844: //10/7661A559800A/H323/h245_address_ind: ev=0
000203: Oct 5 10:19:56.844: //10/7661A559800A/CCAPI/ccIsInfoRingback:
000204: Oct 5 10:19:56.844: //10/7661A559800A/H323/cch323_get_embedded_obj_from_ccb: ccb=0x49F6FE00, tag=17, size=83
000205: Oct 5 10:19:56.844: //10/7661A559800A/H323/cch323_get_embedded_obj_from_ccb: Extraction PASSED from 0x49F72638
000206: Oct 5 10:19:56.844: //10/7661A559800A/H323/generic_alert_notify: aData display_info
000207: Oct 5 10:19:56.844: //10/7661A559800A/CCAPI/cc_api_call_alert:
Interface=0x478B1418, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
000208: Oct 5 10:19:56.844: //10/7661A559800A/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
000209: Oct 5 10:19:56.844: //10/7661A559800A/H323/cch323_h225_set_new_state: Changing from H225_CALLPROC state to H225_ALERT state
000210: Oct 5 10:19:56.844: //9/7661A559800A/CCAPI/ccCallAlert:
000211: Oct 5 10:19:56.844: //9/7661A559800A/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
000212: Oct 5 10:19:56.848: //9/7661A559800A/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=9
000213: Oct 5 10:19:56.848: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <3001>;tag=39F76DC-E923001>
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <3001>;party=called;screen=no;privacy=off3001>
Contact: <3001>3001>
Content-Length: 0
000214: Oct 5 10:20:04.448: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 3 Event 0x1
000215: Oct 5 10:20:04.448: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x49D55E4C, len=93, msgPtr=0x49D55CF0
000216: Oct 5 10:20:04.448: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
000217: Oct 5 10:20:04.448: H225.0 INCOMING ENCODE BUFFER::= 22C0060008914A0004000303030381522800B500001240013C050401002040007661A559CFC211DF800AB8130721089B1D0C0011007662DDA9CFC211DF800CB8130721089B0180018010800100
000218: Oct 5 10:20:04.448:
000219: Oct 5 10:20:04.448: H225.0 INCOMING PDU ::=
h323-uu-pdu
h323-message-body connect :
ip '03030303'H
port 33106
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
mc FALSE
undefinedNode FALSE
callIdentifier
multipleCalls TRUE
h245Tunneling FALSE
000220: Oct 5 10:20:04.456: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type SETUPCFM_CHOSEN
000221: Oct 5 10:20:04.456: //10/7661A559800A/H323/setup_cfm_ind: ====== PI = 0
000222: Oct 5 10:20:04.456: //10/7661A559800A/H323/setup_cfm_ind: Set new event H225_EV_SETUP_CFM_IND
000223: Oct 5 10:20:04.456: //10/7661A559800A/H323/setup_cfm_ind: Rcvd CONNECT Display Info IE =
000224: Oct 5 10:20:04.456: //10/7661A559800A/H323/setup_cfm_ind: setup_cfm_ind:- Insertion PASSED
000225: Oct 5 10:20:04.456: //10/7661A559800A/H323/cch323_h225_receiver: SETUPCFM_CHOSEN: src address = 6.6.6.7; dest address = 3.3.3.3
000226: Oct 5 10:20:04.456: //10/7661A559800A/H323/run_h225_sm: Received event H225_EV_SETUP_CFM_IND while at state H225_ALERT
000227: Oct 5 10:20:04.456: //10/7661A559800A/H323/setup_cfm_notify: status = 8000009
000228: Oct 5 10:20:04.456: //10/7661A559800A/H323/cch323_h225_set_new_state: Changing from H225_ALERT state to H225_WAIT_FOR_H245 state
000229: Oct 5 10:20:04.456: //10/7661A559800A/H323/h245_address_ind: ev=2
000230: Oct 5 10:20:04.456: //10/7661A559800A/CCAPI/ccIsInfoRingback:
000231: Oct 5 10:20:04.456: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0xB internal event to H245 IWF SM
000232: Oct 5 10:20:04.456: //10/7661A559800A/H323/run_h245_iwf_sm: received IWF_EV_H245_CONNECT_REQ while at state IWF_IDLE
000233: Oct 5 10:20:04.456: //10/7661A559800A/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_CONNECT_REQ_EVENT
000234: Oct 5 10:20:04.456: //10/7661A559800A/H323/cch323_h245_connection_sm: state=0, event=1, ccb=49F6FE00, listen state=0
000235: Oct 5 10:20:04.456: //10/7661A559800A/H323/cch323_h245_connection_sm: H245_CONNECT: Received event H245_CONNECT_REQ_EVENT while at H245_NONE state
000236: Oct 5 10:20:04.460: //10/7661A559800A/H323/cch323_h245_set_new_state: Changing from H245_NONE state to H245_WAITING state
000237: Oct 5 10:20:04.460: //10/7661A559800A/H323/h245_iwf_set_new_state: changing from IWF_IDLE state to IWF_AWAIT_H245_CONN state
000238: Oct 5 10:20:04.460: //10/7661A559800A/H323/h245_connect_init: connection pending
000239: Oct 5 10:20:04.512: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 4 Event 0x1
000240: Oct 5 10:20:04.512: //10/7661A559800A/H323/cch323_h245_channel_established_ind: Using fd=4 to send msgs
000241: Oct 5 10:20:04.512: //10/7661A559800A/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_ESTABLISHED_EVENT
000242: Oct 5 10:20:04.512: //10/7661A559800A/H323/cch323_h245_connection_sm: state=1, event=2, ccb=49F6FE00, listen state=0
000243: Oct 5 10:20:04.512: //10/7661A559800A/H323/cch323_h245_connection_sm: H245_CONNECT: Received event H245_ESTABLISHED_EVENT while at H245_WAITING state
000244: Oct 5 10:20:04.512: //10/7661A559800A/H323/cch323_h245_set_new_state: Changing from H245_WAITING state to H245_CONNECTED state
000245: Oct 5 10:20:04.512: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x2 internal event to H245 IWF SM
000246: Oct 5 10:20:04.512: //10/7661A559800A/H323/run_h245_iwf_sm: received IWF_EV_H245_CONNECTED while at state IWF_AWAIT_H245_CONN
000247: Oct 5 10:20:04.512: //10/7661A559800A/H323/h245_iwf_set_new_state: changing from IWF_AWAIT_H245_CONN state to IWF_H245_CONNECTED state
000248: Oct 5 10:20:04.512: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 4 Event 0x1
000249: Oct 5 10:20:04.712: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 4 Event 0x1
000250: Oct 5 10:20:04.712: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x49F6FE00, len=286, msgPtr=0x49F72AE0
000251: Oct 5 10:20:04.712: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.245
000252: Oct 5 10:20:04.712: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 286
000253: Oct 5 10:20:04.712: H245 MSC INCOMING ENCODE BUFFER::= 027001060008817500078013800014000100000100000100000CC001000100148000184810B50000120C52747044746D6652656C6179000080001E83015080001D83014080001A83011080001421C0138000132180138000122140138000102020B500001209436C6561724368696480000522C00180000422800180000C2400010180000D2408010180000E220000C0000F2020B5000012074737323331617280000A22000040000220C0138000032040138000092240078000082020B500001207473732367233328000072020B500001207473732367232348000062020B50000120747373236723136008001021100040005000C000D0002000300060007000800100009000F000E000A000A00120013001402001D001A001800001E
000254: Oct 5 10:20:04.716:
000255: Oct 5 10:20:04.716: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
sequenceNumber 1
protocolIdentifier { 0 0 8 245 0 7 }
multiplexCapability h2250Capability :
maximumAudioDelayJitter 20
receiveMultipointCapability
multicastCapability FALSE
multiUniCastConference FALSE
mediaDistributionCapability
centralizedControl FALSE
distributedControl FALSE
centralizedAudio FALSE
distributedAudio FALSE
centralizedVideo FALSE
distributedVideo FALSE
transmitMultipointCapability
receiveAndTransmitMultipointCapability
mcCapability
centralizedConferenceMC FALSE
decentralizedConferenceMC FALSE
rtcpVideoControlCapability FALSE
mediaPacketizationCapability
h261aVideoPacketization FALSE
logicalChannelSwitchingCapability FALSE
t120DynamicPortCapability FALSE
capabilityTable
capabilityTableEntryNumber 25
capability receiveAndTransmitDataApplicationCapability :
application nonStandard :
nonStandardIdentifier h221NonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '52747044746D6652656C6179'H
maxBitRate 0
capabilityTableEntryNumber 31
capability receiveUserInputCapability : hookflash : NULL
capabilityTableEntryNumber 30
capability receiveUserInputCapability : dtmf : NULL
capabilityTableEntryNumber 27
capability receiveUserInputCapability : basicString : NULL
capabilityTableEntryNumber 21
capability receiveAudioCapability : g722-48k : 20
capabilityTableEntryNumber 20
capability receiveAudioCapability : g722-56k : 20
capabilityTableEntryNumber 19
capability receiveAudioCapability : g722-64k : 20
capabilityTableEntryNumber 17
capability receiveAudioCapability : nonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '436C65617243686964'H
capabilityTableEntryNumber 6
capability receiveAudioCapability : g729AnnexA : 2
capabilityTableEntryNumber 5
capability receiveAudioCapability : g729 : 2
capabilityTableEntryNumber 13
capability receiveAudioCapability : g729wAnnexB : 2
capabilityTableEntryNumber 14
capability receiveAudioCapability : g729AnnexAwAnnexB : 2
capabilityTableEntryNumber 15
capability receiveAudioCapability : g7231 :
maxAl-sduAudioFrames 1
silenceSuppression TRUE
capabilityTableEntryNumber 16
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '47373233316172'H
capabilityTableEntryNumber 11
silenceSuppression FALSE
capability receiveAudioCapability : g711Ulaw64k : 20
capabilityTableEntryNumber 4
capability receiveAudioCapability : g711Alaw64k : 20
capabilityTableEntryNumber 10
capability receiveAudioCapability : g728 : 8
capabilityTableEntryNumber 9
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '47373236723332'H
capabilityTableEntryNumber 8
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '47373236723234'H
capabilityTableEntryNumber 7
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '47373236723136'H
capabilityDescriptors
capabilityDescriptorNumber 1
simultaneousCapabilities
5,
6,
13,
14,
3,
4,
7,
8,
9,
17,
10,
16,
15,
11,
11,
19,
20,
21
30,
27,
25
31
000256: Oct 5 10:20:04.740: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
000257: Oct 5 10:20:04.740: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
000258: Oct 5 10:20:04.740: //-1/xxxxxxxxxxxx/H323/cch323_get_dp_pref_mask:
cch323_get_dp_pref_mask:IPIPGW(10):setting mask for 729ar8also as 729 is configured
000259: Oct 5 10:20:04.740: //-1/xxxxxxxxxxxx/H323/cch323_get_dp_pref_mask:
000260: Oct 5 10:20:04.740: //10/7661A559800A/H323/cch323_h245_cap_ind: Masks au=0x7000B9FF data=0x2 uinp=0x32
000261: Oct 5 10:20:04.740: //10/7661A559800A/H323/cch323_run_h245_cap_in_sm: Received H245_EVENT_CAP_IND while at state IDLE
000262: Oct 5 10:20:04.744: //10/7661A559800A/H323/h245_cap_in_set_new_state: changing from IDLE state to AWAITING_RESPONSE state
000263: Oct 5 10:20:04.744: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x4 internal event to H245 IWF SM
000264: Oct 5 10:20:04.744: //10/7661A559800A/H323/run_h245_iwf_sm: received IWF_EV_CAP_IND while at state IWF_H245_CONNECTED
000265: Oct 5 10:20:04.744: //10/7661A559800A/H323/h323_validate_cap_ind: Remote Pref Codecs UnOrdered (0x7000B9FF) = [G729IETF] [G729a] [G729b] [G729ab] [G711_ULAW_64K] [G711_ALAW_64K] [G726r16] [G726r24] [G726r32] [CLEARCHANNEL] [G728] [G723ar63] [G723r63] [G72264] [G72256] [G72248] []
000266: Oct 5 10:20:04.744: //10/7661A559800A/H323/h245_handle_cap_ind: TCS received from remote end. Setting h245 status flag H245_CAP_REQUEST_RCVD
000267: Oct 5 10:20:04.744: //-1/xxxxxxxxxxxx/H323/cch323_get_dp_pref_mask:
000268: Oct 5 10:20:04.744: //10/7661A559800A/H323/cch323_set_extended_caps: Copying codec list into extended caps structure
000269: Oct 5 10:20:04.744: //10/7661A559800A/H323/cch323_set_extended_caps: G729IETF
000270: Oct 5 10:20:04.744: //10/7661A559800A/H323/cch323_set_extended_caps: G729a
000271: Oct 5 10:20:04.744: //10/7661A559800A/H323/cch323_iwf_cap_notify: Mask sent to other leg=C
000272: Oct 5 10:20:04.744: //10/7661A559800A/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=10,
Caps(Codec=0xC, Fax Rate=0x2, Vad=0x2,
Modem=0x0, Codec Bytes=20, Signal Type=2)
000273: Oct 5 10:20:04.744: //10/7661A559800A/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
000274: Oct 5 10:20:04.748: //9/7661A559800A/CCAPI/cc_api_call_disconnected:
Cause Value=65, Interface=0x4705BD7C, Call Id=9
000275: Oct 5 10:20:04.748: //9/7661A559800A/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=65, Retry Count=0)
000276: Oct 5 10:20:04.748: //9/7661A559800A/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=9,
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=2050)
000277: Oct 5 10:20:04.748: //10/7661A559800A/H323/cch323_h225_sent_deferred_setup_cfm_notify: ====== PI = 0; status = 8000019
000278: Oct 5 10:20:04.748: //10/7661A559800A/CCAPI/cc_api_call_connected:
Interface=0x478B1418, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
000279: Oct 5 10:20:04.748: //10/7661A559800A/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
000280: Oct 5 10:20:04.748: //10/7661A559800A/H323/cch323_modify_rtcp_session_parameters: updating RTP session params, h245.iwf_state = 2,h245.status = 21020040, in_type = 3, flag = 0
000281: Oct 5 10:20:04.748: //10/7661A559800A/H323/h245_handle_cap_ind: TCS ack is deferred
000282: Oct 5 10:20:04.752: //10/7661A559800A/H323/h245_iwf_set_new_state: changing from IWF_H245_CONNECTED state to IWF_AWAIT_PEER_CAP state
000283: Oct 5 10:20:04.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 501 Not Implemented
CSeq: 101 INVITE
Reason: Q.850;cause=65
Content-Length: 0
000284: Oct 5 10:20:04.756: //-1/xxxxxxxxxxxx/H323/cch323_post_call_statistics: callID=10
000285: Oct 5 10:20:04.756: //10/7661A559800A/CCAPI/ccCallDisconnect:
Cause Value=65, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000286: Oct 5 10:20:04.756: //10/7661A559800A/CCAPI/ccCallDisconnect:
Cause Value=65, Call Entry(Responsed=TRUE, Cause Value=65)
000287: Oct 5 10:20:04.756: //10/7661A559800A/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
000288: Oct 5 10:20:04.756: //9/7661A559800A/CCAPI/ccCallDisconnect:
Cause Value=65, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=65)
000289: Oct 5 10:20:04.756: //9/7661A559800A/CCAPI/ccCallDisconnect:
000290: Oct 5 10:20:04.760: //9/7661A559800A/CCAPI/cc_api_call_disconnect_done:
Disposition=-11, Interface=0x4705BD7C, Tag=0x0, Call Id=9,
Call Entry(Disconnect Cause=65, Voice Class Cause Code=0, Retry Count=0)
000291: Oct 5 10:20:04.760: //9/7661A559800A/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
000292: Oct 5 10:20:04.760: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000293: Oct 5 10:20:04.760: :cc_free_feature_vsa freeing 49E81050
000294: Oct 5 10:20:04.760: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000295: Oct 5 10:20:04.760: vsacount in free is 1
000296: Oct 5 10:20:04.764: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:3001@6.6.6.7:5060 SIP/2.0
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
000297: Oct 5 10:20:04.768: //10/7661A559800A/H323/cch323_peer_caps_ack: Sending caps resp event to CAP sm
000298: Oct 5 10:20:04.768: //10/7661A559800A/H323/run_h245_iwf_sm: received IWF_EV_PEER_CAPS_ACK while at state IWF_AWAIT_PEER_CAP
000299: Oct 5 10:20:04.768: //10/7661A559800A/H323/cch323_do_call_disconnect: gw_id=1, discCause=65
000300: Oct 5 10:20:04.768: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x9 internal event to H225 SM
000301: Oct 5 10:20:04.768: //10/7661A559800A/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_WAIT_FOR_H245
000302: Oct 5 10:20:04.768: //10/7661A559800A/H323/cch323_h225_send_release: Cause = 65; Location = 0
000303: Oct 5 10:20:04.768: //10/7661A559800A/H323/cch323_h225_send_release: h225TerminateRequest: src address = 101058055; dest address = 3.3.3.3
000304: Oct 5 10:20:04.768: H225.0 OUTGOING PDU ::=
h323-uu-pdu
h323-message-body releaseComplete :
callIdentifier
h245Tunneling FALSE
000305: Oct 5 10:20:04.768: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011007662DDA9CFC211DF800CB8130721089B10800100
000306: Oct 5 10:20:04.768:
000307: Oct 5 10:20:04.772: //10/7661A559800A/H323/cch323_h225_set_new_state: Changing from H225_WAIT_FOR_H245 state to H225_IDLE state
000308: Oct 5 10:20:04.772: //10/7661A559800A/H323/cch323_call_generic_cleanup: Disconnected flag 1
000309: Oct 5 10:20:04.772: //10/7661A559800A/H323/cch323_store_call_history_entry: Call Active Playout Mode: 1,Init 60, Min 40, Max 1000, Fax 300
000310: Oct 5 10:20:04.772: //10/7661A559800A/H323/cch323_store_call_history_entry: Call History Playout Mode: 1,Init 60, Min 40, Max 1000, Fax 300
000311: Oct 5 10:20:04.772: //10/7661A559800A/H323/run_h245_iwf_sm: received IWF_EV_H245_DISCONN while at state IWF_AWAIT_PEER_CAP
000312: Oct 5 10:20:04.772: //10/7661A559800A/H323/defaultHdlr: DEFAULT: Received IWF_EV_H245_DISCONN in state IWF_AWAIT_PEER_CAP
000313: Oct 5 10:20:04.772: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 4
000314: Oct 5 10:20:04.772: //10/7661A559800A/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x478B1418, Tag=0x0, Call Id=10,
000315: Oct 5 10:20:04.772: //10/7661A559800A/CCAPI/cc_api_call_disconnect_done:
000316: Oct 5 10:20:04.772: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000317: Oct 5 10:20:04.776: :cc_free_feature_vsa freeing 49E80F70
000318: Oct 5 10:20:04.776: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000319: Oct 5 10:20:04.776: vsacount in free is 0
000320: Oct 5 10:20:04.776: //-1/xxxxxxxxxxxx/H323/cch323_call_generic_cleanup: Freeing ccb (0x49F6FE00)
000321: Oct 5 10:20:05.104: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 3 Event 0x1
000322: Oct 5 10:20:05.104: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x49D55E4C, len=46, msgPtr=0x49D8C6B8
000323: Oct 5 10:20:05.104: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for H.225
000324: Oct 5 10:20:05.104: //-1/xxxxxxxxxxxx/H323/validate_crv: No CCB for crv: 0x9
000325: Oct 5 10:20:05.104: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Parse error RXDATA_NONE
000326: Oct 5 10:20:05.104: //-1/xxxxxxxxxxxx/H323/cch323_cleanup_xport: CRV entry not found, returning
000327: Oct 5 10:20:22.820: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_PERIODIC_RRQ_TIMER] expired
000328: Oct 5 10:20:22.820: //-1/xxxxxxxxxxxx/H323/cch323_send_event_to_ras: Queued event CCH323_RAS_EVENT_SEND_LT_RRQ to RAS Global SM
000329: Oct 5 10:20:22.820: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0xA internal event to RAS Global SM
000330: Oct 5 10:20:22.820: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: received event CCH323_RAS_EVENT_SEND_LT_RRQ while at CCH323_RAS_STATE_IDLE state
000331: Oct 5 10:20:22.820: RAS OUTGOING PDU ::=
requestSeqNum 1264
callSignalAddress
rasAddress
ipAddress :
ip '06060607'H
port 63383
terminalType
mc FALSE
undefinedNode FALSE
endpointVendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
timeToLive 60
keepAlive TRUE
000332: Oct 5 10:20:22.824: RAS OUTGOING ENCODE BUFFER::= 0E4004EF060008914A00048000010006060607F7970006005A004F004E0045005F0030003100B5000012288F000002003B0180211E003600370032004300390046003600430030003000300030003000300030003101000180
000333: Oct 5 10:20:22.824:
000334: Oct 5 10:20:22.824: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: changing to CCH323_RAS_STATE_RRQ state
000335: Oct 5 10:20:22.888: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
000336: Oct 5 10:20:22.888: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: owner_data=0x49D57F60, len=70, msgPtr=0x49D564A4
000337: Oct 5 10:20:22.888: //-1/xxxxxxxxxxxx/H323/cch323_gw_process_read_socket: Received msg for RAS
000338: Oct 5 10:20:22.888: RAS INCOMING ENCODE BUFFER::= 124004EF060008914A0004000C005A004F004E0045005F003000311E0036003700320043003900460036004300300030003000300030003000300031208A0002003B01000180
000339: Oct 5 10:20:22.888:
000340: Oct 5 10:20:22.888: RAS INCOMING PDU ::=
requestSeqNum 1264
callSignalAddress
timeToLive 60
000341: Oct 5 10:20:22.888: //-1/xxxxxxxxxxxx/H323/cch323_ras_handle_recv_msg: received msg of type RCF_CHOSEN
000342: Oct 5 10:20:22.888: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: received event CCH323_RAS_EVENT_RCF while at CCH323_RAS_STATE_RRQ state
000343: Oct 5 10:20:22.888: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: changing to CCH323_RAS_STATE_IDLE state
ISR#
