Two LDAP on different clusters
Ahmed Elnagar
Dear all;
I have two CM clusters version 7.0 I need to have both users on each cluster to see other cluster users using Corporate directory and be able to search for them and dial them...how it is possible to do so??
I have think of adding on cluster A users of cluster B as normal users and assign them DNs that correspond to the way Cluster A calls cluster B...but this will be double work and extra headech...is there a way to integrate the two LDAP directories?
Ahmed Elnagar
htluo
Level 9
Level 9
This cannot be done with the default/built-in "corporate directory". However, you may configure the "URL Directory" to point to your own XML. Then you have to do some developer job to code it.
Michael
If you integrate both clusters to the same AD and look into the same OUs you'll get the same info
Otherwise as Michael stated you need to create your own directory script.
java
if this helps, please rate
java
