02-09-2011 06:04 AM - edited 03-16-2019 03:21 AM
we have some UC 8.X appliances (CUCM 8.X, CUCCX 8.X, ...).
Which are the CLI or web commands to retrieve all the the information for their License MACs?
This to have all the data for a new installation in case of a disaster recovery (and to obtain the same License MACs).
Best regards.
Solved! Go to Solution.
02-09-2011 08:03 AM
Yes, all those information could be retrieved either from web or from CLI.
For example,
show status
show network eth0
utils ntp status
show web-security
You may find more information from CLI guide.
Michael
02-09-2011 06:23 AM
Type "show status" from CLI. You'll see a line states "License MAC".
Michael
02-09-2011 06:59 AM
Dear Michael,
I need to retrieve the information (network, certificate, ...) that have brought to that License MAC.
The License MAC is the is the point of departure, not the arrival...
Regards.
02-09-2011 07:23 AM
If your purpose was disaster recoery, you should use DRS instead of re-type those information piece by piece. One typo could trigger a totally different license MAC.
License MAC is a hash of multiple system attributes like physical MAC, NTP, certificate, etc. Try to piece those together would be a pain in neck.
When you do the DRS backup, all those information including license will be backed up.
Michael
02-09-2011 07:59 AM
Dear Michael,
what appens if the DRS doesn't work?
Is there a manual way to retrieve all the data (even though it should be possible to make errors during the typing...)?
Regards.
02-09-2011 08:03 AM
For example,
show status
show network eth0
utils ntp status
show web-security
Michael
02-09-2011 10:17 AM
Dear Michael,
thank you for the answer!
I think that you have missed only one command:
show smtp
but together the commands that you have indicated I can retrieve all the information! :-)
Thanks again and regards.
02-09-2011 11:04 AM
The License MAC is derirved from a hash a hash of TimeZone+NTPServer+NICSpeedandDuplex+IP,Netmask,Gateway+DNS+SMTP+Org,Unit,Location,State,Country.
