UC520 2xBRI basic setup instruction
roydennemans
I'm new to Cisco voice.
I have a UC520 2xBRI (seperate lines with 2 blocks of 4 numbers).
Can someone give me the basic steps
to get BRI working?
I only need a simple setup.
Number forward to hunt group for general use (office number) and direct forwaring to specific telephones.
I see the line light up on call but I do not understand how to handle incoming calls.
Kind regards
Vincent
24 Replies 24
Hi, if you want them to see your extension calling number, you can set again a translation rule. Looking at the configuration, have you understood now how it works ? Also, if you have two bris active, you need trunk group. The config assistant isn't able to do these things.
I created the trunk group using command line.
This also works.
But I still have troubles with the dial plan. (In the CCA is only North American plan available).
I changed some values and can now call
regional numbers as follows:
Our number starts with 024 and then 7 digits
I can call all other numbers that start with 024 in our region. I can not call e.g. Amsterdam starting with 020
Also I can not call mobile numbers which start with 06 and then 8 digits
Can you explain me (perhaps small example) how to change this correctly in command line?
Your help is much appreciated.
Kind regards.
Sure. Let's assume you do not use any digit as access for external calls (thing that sually users like very much ebcuae it's like calling from home:
dial-peer voice 58 pots
desc international
destination-pattern 001.....T
prefix 001
trunkgroup bri
dial-peer voice xxx pots
desc cellphones
destination-pattern 06........
trunkgroup bri
desc national
destination-pattern 0[1-9]........
prefix 0
trunkgroup bri
desc emergency
destinaion-pattern 112
prefix 112
trunkgroup bri
Then you can remove the ununsed DPs.
Thanks, this works!!
One last question, incoming callerID is displayed without the 0 making it not possible to return missed calls (wrong number obviously) How do I correct this?
Kind regards,
Add a translation-profile to the trunk group, for incoming, and recall teh following rule against calling number:
voice translation-rule 300
rule 1 // /0/ type national national
rule 2 // /00/ type international international
How do I select the default outbound ISDN number. isdn calling-number does not work.
The customer wants to use the 3th number of the block of 4 numbers. The line defaults to the first number on outbound calling.
You can use either a translation rule at trunk-group level, or under each interface bri
isdn calling-number XXX
Note possibly you have to specify it without the 0.
In any case check what you're sending with "debug isdn q931" and "term mon".
Hello, I understand your config but somehow I can not get it working, I did this
voice translation-rule 4
rule 2 // /00/ type international national
voice translation-profile Add_Zero
translate called 4
dial-peer voice 50 pots
trunkgroup ISDN-LINES
description ** incoming dial peer **
translation-profile incoming Add_Zero
incoming called-number .%
direct-inward-dial
prefix 0
dial-peer voice 51 pots
direct-inward-dial
prefix 0
This does not add zero's
Kind regards.
Apparently I did not understand it,
I configured the profile on the ISDN-Trunk and now it's working, so please discard the config above.
Thank you very much for the excellent instructions!
My vlans were damaged in some way?
I have added a temp vlan using command line
which gives me access again to the unit.
I will try to update to the latest version (I see 15 feb 08 is the latest) first.
