07-08-2011 01:14 AM - edited 03-16-2019 05:50 AM
I have setup a UC560 with AA. When I dial the AA number from the internal extensions everything works. When a call comes from the SIP the AA answers the call but it cannot recognize any options that I send through the phone.
For example I have "0" to transfer the call to the operator and "1" to dial by extension but when I press the button on the phone nothing works. It just keep playing the welcome message for 3 times and then it transferred the call to the number I have under "No Options Transfer To:".
Any suggestions will be very helpful.
CZ
07-08-2011 05:13 AM
Hello
this sems to be a DTMF issue , can you give the exact call flow , you say from sip , is it your profider or an internal sip phone ??
Regrads
07-12-2011 09:19 AM
Hello and thanks for your response.
I have checked the DTMF issue and I have added under dial-peer of the pilot number the config:
voice-class sip dtmf-relay force rtp-nte
Do I need anything else?
07-12-2011 05:44 PM
It's not enough to just change the dtmf method under the voip dial peer to AA. You need to make sure that whichever dtmf method you are using on CME also matches CUE. What dtmf method do you have configured under ccn subsystem sip on cue?
For simplicity, assuming you are using rtp-nte for dtmf to the telco, just configure 'dtmf-relay rtp-nte' on the AA pilot dial peer (no need to use the 'voice-class sip dtmf-relay force rtp-nte), and configure 'dtmf-relay rtp-nte under 'ccn subsystem sip' in cue.
07-27-2011 07:44 AM
I have checked all the dtmf configuration and is correct. However when I run the command
show voip rtp connection i get the following:
VoIP RTP active connections :
No. CallId dstCallId LocalRTP RmtRTP LocalIP RemoteIP
1 49 50 18274 27896 192.168.0.230 xxx.xxx.xxx.xxx
2 50 49 17236 16898 xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
Found 2 active RTP connections
What I cannot figure out is the IP 192.168.0.230. This is my IP towards my LAN. I do not use the UC as my router but only as my Call Manager. My SIP Trunk connection is directly connected on the WAN port of the UC. So any traffic towards my SIP provider should go through the IP that I have configured on my WAN port and not through the IP that I connect the UC on my LAN.
I have checked and is not routing issue.
