CUCM 7.1 - End User modifying BLFs Question
coconino1969
Hello all,
Using CUCM 7.1
Can an end user using the Cisco User Login be able to modify BLFs in a Cisco 7960 with a 7914 module?
Justin Brenton
Level 4
Level 4
Hi coconino1969,
Unfortunately you cannot do this using CCMUser,  CCM Administrators would need to change this.
I'm sure this is a security restriction.
HTH,
Justin
Justin Brenton
Level 4
Level 4
Hi coconino1969,
HTH,
Justin
Thank you Justin.
Appreciate your quick response.
