Hi Kenneth,
I would first start off with checking the supervisor capability under Tools and User Management to make sure you are listed. Then I would check the "teams" settings under Subsystem/RmCm and choosing the appropriate team and checking the selections for both the primary supervisor and secondary supervisor selections to see if you are listed.
Tony
Please rate helpful posts!
Tony
