UCM 6.0.1 Device Pool Missing MoH Fields
tim_roper2
I do not see the "User Hold MOH Audio Source" or "Network Hold MOH Audio Source" fields when configuring a Device Pool. Were these fields removed in UCM 6.0? Thanks, Tim
Jaime Valencia
they're under the common profile now
java
if this helps, please rate
java
Jaime Valencia
java
java
Thanks, I found it under Device --> Device Settings --> Common Device Configuration
