UCM Upgrade to 8.6 - Feature license question
torsten.brink
17 Replies 17
Thanks a lot for the update.
It's not too bad for me, so I have to install 8.6 from the NFR kit and then upgrade to 8.6.2a. I just wanted to avoid moving over the existing config from 8.5.1 via export/import. It's just a demo system, not a lot to carry over.
Best
   Patrick
Hi all,
I've also encountered the same issue posted in this thread and resolved it according to the method
"Request new demo licenses" described in CSCtr77210 which Rob quoted. I've uploaded the demo license
onto my CCM and worked well since then.
As you know, we can get Demo License in the following Cisco site. I think the procedure is quite easy and smooth.
http://www.cisco.com/go/license
Takao
Do they expire though?
