06-29-2009 05:59 AM - edited 03-15-2019 06:44 PM
Does anybody know what the maximum amount of participants is in a meet me conference on UCM 7, using the software conf bridge has this been increased from version 4
Solved! Go to Solution.
06-29-2009 06:03 AM
Theoretically it's 128 (all the streams CFB can handle), best practice states maximum 48.
java
if this helps, please rate
06-29-2009 06:03 AM
java
06-29-2009 06:06 AM
hi Java can you send me a url were i can find this info i need it for a proposal, thanks for the info.
dw
06-29-2009 06:16 AM
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K30585600
I recall it's also in CUCM docs, should be in the media resources section or sw resources but i can't find it right now.
Above is still valid for any CUCM version.
java
06-29-2009 06:19 AM
cheers thanks for info
dw ccie #13955
