UCS C200 M2 HD Error
yn_balti09
Dear All,
we have Cisco IP telephony system with 2 Call Manager (UCS C200 M2) with around 1200 cisco IP Phones.
suddenly Pub gives HD error Indicator (yellow Led) after 10 days same issue happened in SUB..
I need support how i can fix this issue..
looking for your advice.
thanks
Yahya
Jaime Valencia
Log via CIMC and check the HDD/RAID status, if necessary, call TAC (depending on who supports your HW) as a new HDD might be necessary.
java
if this helps, please rate
you can also have a look on the below docs:
https://supportforums.cisco.com/discussion/11467171/cisco-ucs-c200-m2-showing-amber-light-mem-and-warning
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ts/guide_old_FM/TS_Server.html
