Cisco 3945 voice gateway for Lync and intelepeer.
aphillips999
I am trying to setup a 3945 as a SIP to SIP gateway for lync.
I am not able to dial out or in.  I can see the incoming calls getting to LYNC and it attempting to process it, but I only get one way RTP.   One number, it looks like the call goes to the device, then the device immediately calls the calling number and then repeat
IE:
From Outside to Inside Canceled
From Inside to outside  Canceled
From Inside to outside  Canceled ...
The outbound gets from Lync to the router, and seems to be attempting to go back out the proper Dial Plan but I end up with a fast busy.
I am trying to learn this as I am doing it, which is never the best way!  But it is what it is.   So any feedback would be excellent!
Thank you!
The Cleansed Config:
dial-peer voice 100 voip
description Incoming dial peer - from IntelePeer (1xxxxxx.... numbers)
translation-profile incoming rmv_plus
huntstop
incoming called-number +1xxxxxx....
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 102 voip
description Incoming dial peer - from Lync
huntstop
incoming called-number ^.T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
description Outgoing dial peer - to IntelePeer
huntstop
destination-pattern +
session protocol sipv2
session target sip-server
session transport tcp
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay rtp-nte
no vad
dial-peer voice 300 voip
description ** SIP Trunk to Lync Core **
translation-profile outgoing add_plus
huntstop
destination-pattern XXXXXX....
session target ipv4:{MediationServer}:5060
voice-class codec 1
voice-class sip localhost dns:SIPDomain.com
dtmf-relay rtp-nte
no vad
sip-ua
retry invite 2
retry bye 2
retry cancel 2
retry register 10
sip-server ipv4:(Intelepeer Signaling Address)
ip address trusted list
IPV4: {Mediation Server}
IPV4: {Intelepeer Signaling}
IPV4: {Intelepeer Media}
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
9 Replies 9
Nadeem Ahmed
can you please run some test and collect the below debugs
debug voice ccapi inout
debug ccsip message
debug ccsip error
also share show run from GW.
Br,
Nadeem Ahmed
PS: Please rate all useful post.
Br, Nadeem Please rate all useful post.
Here is the Running Config:    Will now go run Debugs.
version 15.2
service password-encryption
hostname SBC-R3900-A
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 1/1
enable secret 5
enable password 7
no aaa new-model
memory-size iomem 25
no network-clock-participate slot 1
no ipv6 cef
no ip routing
no ip cef
voice-card 0
voice-card 1
voice rtp send-recv
voice service voip
ipv4 10.I.I.4 -- Mediation Server
ipv4 10.I.I.5 -- Mediation Server
ipv4 68.68.X.X -- Intelepeer Signaling
ipv4 68.68.X.X -- Intelepeer Media
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
rel1xx disable
min-se 180 session-expires 180
early-offer forced
midcall-signaling passthru
voice class codec 1
voice translation-rule 10
rule 1 /^\+1\(..........\)$/ /\1/
voice translation-rule 20
rule 1 /^\(1..........\)$/ /+\1/
rule 2 /^\011\(.*\)$/ /+\1/
rule 3 /^\(..........\)$/ /+1\1/
voice translation-profile add_plus
translate calling 20
translate called 20
voice translation-profile rmv_plus
translate calling 10
translate called 10
license udi pid C3900-SPE250/K9 sn FOC17036K4W
hw-module pvdm 0/0
redundancy
interface GigabitEthernet0/0
no ip address
no ip route-cache
duplex auto
speed auto
no mop enabled
bridge-group 1
interface GigabitEthernet0/0.101
description VLAN_WS_Fiber
encapsulation dot1Q 101
ip address 64.X.X.25 255.255.255.224
ip virtual-reassembly in
no ip route-cache
interface GigabitEthernet0/0.102
description VLAN_Cox_Cable
encapsulation dot1Q 102
no ip route-cache
interface GigabitEthernet0/0.103
description VLAN_Cox_Fiber
encapsulation dot1Q 103
no ip route-cache
interface GigabitEthernet0/0.104
description VLAN_Frontier_Fiber
encapsulation dot1Q 104
no ip route-cache
interface GigabitEthernet0/1
no ip address
no ip route-cache
duplex auto
speed auto
no mop enabled
bridge-group 1
interface GigabitEthernet0/2
no ip address
no ip route-cache
duplex auto
speed auto
no mop enabled
bridge-group 1
interface GigabitEthernet0/2.5
description Internal
encapsulation dot1Q 5
ip address 10.X.X.100 255.255.255.0
no ip route-cache
interface GigabitEthernet0/3
no ip address
no ip route-cache
duplex auto
speed auto
no mop enabled
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route I.I.I.0 255.255.255.0 I.I.I.6
ip route 68.68.x.x 255.255.255.255 64.X.X.1
dialer-list 1 protocol ip permit
nls resp-timeout 1
cpd cr-id 1
control-plane
bridge 1 protocol dec
mgcp profile default
description Incoming dial peer - from IntelePeer (1XXXXXX.... numbers)
huntstop
incoming called-number +1XXXXXX....
voice-class codec 1
dtmf-relay rtp-nte
no vad
huntstop
voice-class codec 1
dtmf-relay rtp-nte
no vad
huntstop
voice-class codec 1
dtmf-relay rtp-nte
no vad
huntstop
session target ipv4:10.I.I.4:5060
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
fax protocol pass-through g711ulaw
no vad
gateway
timer receive-rtp 1200
sip-ua
retry invite 2
retry bye 2
retry cancel 2
retry register 10
sip-server ipv4:68.68.X.X -- Intelepeer Signaling
gatekeeper
shutdown
alias exec SAVE copy run start
banner motd ^C
SE^C
line con 0
exec-timeout 0 0
password 7 0045120209520547
logging synchronous
login local
line aux 0
line vty 0 4
exec-timeout 20 0
password 7 114818011A1B054D
logging synchronous
login
transport input all
line vty 5 294
login
transport input all
scheduler allocate 20000 1000
end
SBC-R3900-A#
It seems I forgot to add Routing when I restarted fresh.  After adding that some inbound started working.  Have not fully tested it.
The strange circular call is still happening.  I will add those debugs.  I will have to test the outbound when I get into the office.
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com;user=phone>;epid=373B149707;tag=fb611e1c2
TO: <sip:+1INTERNALCALLERPHONE@CISCISBCPRIVATEIP;user=phone>
CSEQ: 673622 INVITE
CALL-ID: 17465ade-4a0b-46bf-95cf-906057162cf9
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP MEDIATION1IP:50733;branch=z9hG4bK486e5ff8
CONTACT: <sip:hestia-l1.olympus.local:5060;transport=Tcp;maddr=MEDIATION1IP;ms-opaque=bdf9c42b0b54f3d9>
CONTENT-LENGTH: 330
SUPPORTED: 100rel
USER-AGENT: RTCC/5.0.0.0 MediationServer
CONTENT-TYPE: application/sdp
ALLOW: ACK
ms-call-source: non-ms-rtc
Allow: CANCEL,BYE,INVITE,PRACK,UPDATE
v=0
o=- 49151 1 IN IP4 MEDIATION1IP
s=session
c=IN IP4 MEDIATION1IP
b=CT:1000
t=0 0
m=audio 50720 RTP/AVP 97 101 13 0 8
a=rtcp:50721
a=label:Audio
a=sendrecv
a=rtpmap:97 RED/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=ptime:20
Dec 15 22:14:26.959: //-1/09F3E25E8375/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
SIP: (564) Attribute mid, level 1 instance 1 not found.
Dec 15 22:14:26.959: //564/09F3E25E8375/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
Dec 15 22:14:26.959: //564/09F3E25E8375/SIP/Error/sipSPI_ipip_update_call_entry:
Dec 15 22:14:26.959: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count: Unable to set CHANNEL_COUNT for callid 564
Dec 15 22:14:26.959: //564/09F3E25E8375/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo: Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
Dec 15 22:14:26.959: //564/09F3E25E8375/SIP/Error/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
Dec 15 22:14:26.959: //564/09F3E25E8375/SIP/Error/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
Dec 15 22:14:26.959: //-1/09F3E25E8375/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=+1EXTERNALCALLERPHONE
----- ccCallInfo IE subfields -----
cisco-ani=+1EXTERNALCALLERPHONE
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=+1INTERNALCALLERPHONE
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Dec 15 22:14:26.959: //-1/09F3E25E8375/CCAPI/cc_api_call_setup_ind_common:
Interface=0x1DE1F444, Call Info(
Calling Number=+1EXTERNALCALLERPHONE,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=+1INTERNALCALLERPHONE(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=564
Dec 15 22:14:26.959: //-1/09F3E25E8375/CCAPI/ccCheckClipClir:
In: Calling Number=+1EXTERNALCALLERPHONE(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=+1EXTERNALCALLERPHONE(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Dec 15 22:14:26.959: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Dec 15 22:14:26.959: :cc_get_feature_vsa malloc success
Dec 15 22:14:26.959: cc_get_feature_vsa count is 3
Dec 15 22:14:26.959: :FEATURE_VSA attributes are: feature_name:0,feature_time:537735680,feature_id:126
Dec 15 22:14:26.959: //564/09F3E25E8375/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=+1EXTERNALCALLERPHONE(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=+1INTERNALCALLERPHONE(TON=Unknown, NPI=Unknown))
Dec 15 22:14:26.959: //564/09F3E25E8375/CCAPI/cc_process_call_setup_ind:
Event=0x1AE14DD8
Dec 15 22:14:26.959: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number +1INTERNALCALLERPHONE
Dec 15 22:14:26.959: //564/09F3E25E8375/CCAPI/ccCallSetContext:
Context=0x20313DC4
>>>>CCAPI handed cid 564 with tag 100 to app "_ManagedAppProcess_Default"
Dec 15 22:14:26.959: //564/09F3E25E8375/CCAPI/ccCallProceeding:
Dec 15 22:14:26.959: //564/09F3E25E8375/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=300, Params=0x20315214, Progress Indication=NULL(0)
Dec 15 22:14:26.959: //564/09F3E25E8375/CCAPI/ccCheckClipClir:
Destination Pattern=860207...., Called Number=+1INTERNALCALLERPHONE, Digit Strip=FALSE
Redirect Number=, Display Info=Caller Name
Account Number=+1EXTERNALCALLERPHONE, Final Destination Flag=TRUE,
Guid=09F3E25E-A2B0-11E5-8375-88420441C971, Outgoing Dial-peer=300
Dec 15 22:14:26.959: //564/09F3E25E8375/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Dec 15 22:14:26.959: //564/09F3E25E8375/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x1DE1F444, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=+1EXTERNALCALLERPHONE,(Calling Name=Caller Name)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=+1INTERNALCALLERPHONE(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=300, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Dec 15 22:14:26.959: cc_get_feature_vsa count is 4
Dec 15 22:14:26.959: :FEATURE_VSA attributes are: feature_name:0,feature_time:537735456,feature_id:127
Dec 15 22:14:26.959: //565/09F3E25E8375/SIP/Error/ccsip_ipip_media_forking_read_from_TDContainer: MF: Unable to read data from TD Container..
Dec 15 22:14:26.959: //565/09F3E25E8375/SIP/Error/ccsip_ipip_media_forking_forked_leg_config: MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
Dec 15 22:14:26.959: //565/09F3E25E8375/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Dec 15 22:14:26.959: //565/09F3E25E8375/CCAPI/ccCallSetContext:
Context=0x203151C8
Dec 15 22:14:26.959: //564/09F3E25E8375/CCAPI/ccSaveDialpeerTag:
Dec 15 22:14:26.959: //565/09F3E25E8375/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
Dec 15 22:14:26.959: //565/09F3E25E8375/SIP/Error/sip_iwf_sip_copy_channelInfo_to_sdp: We are either escalating, orno stream found for this m-line index:1
Dec 15 22:14:26.959: //565/09F3E25E8375/CCAPI/cc_api_event_indication:
Event=184, Call Id=565
Event Is Sent To Conferenced SPI(s) Directly
Dec 15 22:14:26.959: //564/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Dec 15 22:14:26.959: cc_api_get_xcode_stream : 4802
Dec 15 22:14:26.959: //565/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Dec 15 22:14:26.959: //565/09F3E25E8375/CCAPI/cc_api_call_proceeding:
Interface=0x1DE1F444, Progress Indication=NULL(0)
SIP: (565) Group (a= group line) attribute, level 65535 instance 1 not found.
Dec 15 22:14:26.959: //564/09F3E25E8375/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP MEDIATION1IP:50733;branch=z9hG4bK486e5ff8
From: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com;user=phone>;epid=373B149707;tag=fb611e1c2
To: <sip:+1INTERNALCALLERPHONE@CISCISBCPRIVATEIP;user=phone>
Date: Tue, 15 Dec 2015 22:14:26 GMT
Call-ID: 17465ade-4a0b-46bf-95cf-906057162cf9
CSeq: 673622 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.1.T2.1
Content-Length: 0
Dec 15 22:14:26.959: //565/09F3E25E8375/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+1INTERNALCALLERPHONE@MEDIATION1IP:5060 SIP/2.0
Via: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK471E7E
Remote-Party-ID: "Caller Name" <sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;party=calling;screen=no;privacy=off
From: "Caller Name" <sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE48AC-197
To: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>
Call-ID: 9F3E25E-A2B011E5-837B8842-441C971@SIPDOMIN.com
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 180
Cisco-Guid: 0166978142-2729447909-2205517890-0071420273
User-Agent: Cisco-SIPGateway/IOS-15.2.1.T2.1
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1450217666
Contact: <sip:+1EXTERNALCALLERPHONE@CISCISBCPRIVATEIP:5060;transport=tcp>
Expires: 180
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 240
v=0
o=CiscoSystemsSIP-GW-UserAgent 586 9228 IN IP4 CISCISBCPRIVATEIP
s=SIP Call
c=IN IP4 CISCISBCPRIVATEIP
t=0 0
m=audio 22586 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Dec 15 22:14:26.961: //565/09F3E25E8375/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE48AC-197
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>
CSEQ: 101 INVITE
CALL-ID: 9F3E25E-A2B011E5-837B8842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK471E7E
CONTENT-LENGTH: 0
TIMESTAMP: 1450217666
Dec 15 22:14:28.233: //565/09F3E25E8375/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=8bc8bfe2f;epid=373B149707
CSEQ: 101 INVITE
CONTACT: <sip:hestia-l1.olympus.local:5060;transport=Tcp;maddr=MEDIATION1IP>
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
SERVER: RTCC/5.0.0.0 MediationServer
Dec 15 22:14:28.233: //565/09F3E25E8375/CCAPI/cc_api_event_indication:
Event=98, Call Id=565
Dec 15 22:14:28.233: //565/09F3E25E8375/CCAPI/cc_api_call_cut_progress:
Interface=0x1DE1F444, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255),
Cause Value=0
Call Entry(Responsed=TRUE)
Dec 15 22:14:28.233: //564/09F3E25E8375/CCAPI/ccCallCutProgress:
Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Dec 15 22:14:28.233: //564/09F3E25E8375/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+1INTERNALCALLERPHONE@CISCISBCPRIVATEIP;user=phone>;tag=CE4DA6-33B
CSeq: 673622 INVITE
Remote-Party-ID: <sip:+1INTERNALCALLERPHONE@CISCISBCPRIVATEIP>;party=called;screen=no;privacy=off
Contact: <sip:+1INTERNALCALLERPHONE@CISCISBCPRIVATEIP:5060;transport=tcp>
Content-Length: 0
Dec 15 22:14:28.433: //563/090D2D29836E/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE42C6-772
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=eef5bdac83;epid=373B149707
CSEQ: 101 INVITE
CALL-ID: 90D7B3D-A2B011E5-83748842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK46F3C
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:28.433: //563/090D2D29836E/CCAPI/cc_api_event_indication:
Event=98, Call Id=563
Dec 15 22:14:28.433: //563/090D2D29836E/CCAPI/cc_api_call_cut_progress:
Cause Value=0
Dec 15 22:14:28.433: //562/090D2D29836E/CCAPI/ccCallCutProgress:
Dec 15 22:14:28.433: //562/090D2D29836E/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP INTELEPEERSIGNALING:5060;branch=z9hG4bK-002-92b15dc-515e8999
From: "Caller Name" <sip:+1EXTERNALCALLERPHONE@INTELEPEERSIGNALING:5060;user=phone>;tag=92b15dc0a010100
To: <sip:+1INTERNALCALLERPHONE@MYPUBLICIP:5060;user=phone>;tag=CE47A4-195C
Date: Tue, 15 Dec 2015 22:14:25 GMT
Call-ID: 1-92b15dc0a010100.136afe3e@INTELEPEERSIGNALING
CSeq: 2 INVITE
Remote-Party-ID: <sip:+1INTERNALCALLERPHONE@MYPUBLICIP>;party=called;screen=no;privacy=off
Contact: <sip:+1INTERNALCALLERPHONE@MYPUBLICIP:5060;transport=tcp>
Content-Length: 0
Dec 15 22:14:28.495: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+1INTERNALCALLERPHONE@CISCISBCPRIVATEIP;user=phone SIP/2.0
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com;user=phone>;epid=373B149707;tag=c45eeb28a
CSEQ: 673623 INVITE
CALL-ID: 9b794e05-f126-4a10-9290-1d4c906c80eb
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP MEDIATION1IP:50738;branch=z9hG4bK654044ed
CONTENT-LENGTH: 330
SUPPORTED: 100rel
ALLOW: ACK
v=0
o=- 49152 1 IN IP4 MEDIATION1IP
s=session
b=CT:1000
t=0 0
m=audio 50478 RTP/AVP 97 101 13 0 8
a=rtcp:50479
a=label:Audio
a=sendrecv
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
Dec 15 22:14:28.495: //-1/0ADE4321837C/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
SIP: (566) Attribute mid, level 1 instance 1 not found.
Dec 15 22:14:28.495: //566/0ADE4321837C/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
Dec 15 22:14:28.495: //566/0ADE4321837C/SIP/Error/sipSPI_ipip_update_call_entry:
Dec 15 22:14:28.495: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count: Unable to set CHANNEL_COUNT for callid 566
Dec 15 22:14:28.495: //566/0ADE4321837C/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo: Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
Dec 15 22:14:28.497: //566/0ADE4321837C/SIP/Error/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
Dec 15 22:14:28.497: //566/0ADE4321837C/SIP/Error/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
Dec 15 22:14:28.497: //-1/0ADE4321837C/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
Dec 15 22:14:28.499: //567/0ADE4321837C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE4EAE-2245
CSEQ: 101 INVITE
CALL-ID: ADE9135-A2B011E5-83828842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK48218A
CONTENT-LENGTH: 0
TIMESTAMP: 1450217668
Dec 15 22:14:29.777: //567/0ADE4321837C/SIP/Msg/ccsipDisplayMsg:
Received:
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=88c039417;epid=373B149707
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:29.777: //567/0ADE4321837C/CCAPI/cc_api_event_indication:
Event=98, Call Id=5670.2.2.100>;party=called;screen=no;privacy=off
Content-Length: 0
Dec 15 22:14:29.977: //565/09F3E25E8375/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:30.239: //569/0BC98EB88383/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE54B2-1FF5
CSEQ: 101 INVITE
CALL-ID: BC98EB8-A2B011E5-83898842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK49E05
CONTENT-LENGTH: 0
TIMESTAMP: 1450217670
Content-Length: 0
Dec 15 22:14:32.797: //571/0CB12E2A838A/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE5AA2-B83
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=4620e3f640;epid=373B149707
CSEQ: 101 INVITE
CALL-ID: CB17CD6-A2B011E5-83908842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK4A57F
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:32.797: //571/0CB12E2A838A/CCAPI/cc_api_event_indication:
Event=98, Call Id=57CISCISBCPRIVATEIP>;party=called;screen=no;privacy=off
Content-Length: 0
Dec 15 22:14:32.997: //569/0BC98EB88383/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:34.265: //573/0D9797E98391/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:34.931: //565/09F3E25E8375/SIP/Msg/ccsipDisplayMsg:
Received:
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:34.931: //565/09F3E25E8375/CCAPI/cc_api_event_indication:
Content-Length: 0
Dec 15 22:14:35.981: //573/0D9797E98391/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:37.301: //577/0F5E9C1C839F/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:37.957: //565/09F3E25E8375/SIP/Msg/ccsipDisplayMsg:
Received:
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:37.957: //565/09F3E25E8375/CCAPI/cc_api_event_indication:
Content-Length: 0
Dec 15 22:14:38.993: //575/0E76FAA68398/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:40.309: //581/1129E69983AD/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE77F0-674
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=7fd22992cb;epid=373B149707
CSEQ: 101 INVITE
CALL-ID: 112A34AD-A2B011E5-83B38842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK4F993
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:40.309: //581/1129E69983AD/CCAPI/cc_api_event_indication:
Event=98, Call Id=581
Content-Length: 0
Dec 15 22:14:40.985: //571/0CB12E2A838A/SIP/Msg/ccsipDisplayMsg:
Received:
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:40.985: //571/0CB12E2A838A/CCAPI/cc_api_event_indication:
Event=98, Call Id=571
Content-Length: 0
Dec 15 22:14:42.039: //581/1129E69983AD/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:42.903: //567/0ADE4321837C/SIP/Msg/ccsipDisplayMsg:
Received:
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:42.903: //567/0ADE4321837C/CCAPI/cc_api_event_indication:
Content-Length: 0
Dec 15 22:14:44.013: //573/0D9797E98391/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE6088-5F4
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=2ac955b92;epid=373B149707
CSEQ: 101 INVITE
CALL-ID: D97E5FD-A2B011E5-83978842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK4B10AE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:44.013: //573/0D9797E98391/CCAPI/cc_api_event_indication:
Event=98, Call Id=573
Content-Length: 0
Dec 15 22:14:45.017: //587/13E02B6283C2/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:45.923: //573/0D9797E98391/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:47.023: //581/1129E69983AD/SIP/Msg/ccsipDisplayMsg:
Received:
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:47.023: //581/1129E69983AD/CCAPI/cc_api_event_indication:
Content-Length: 0
Dec 15 22:14:48.027: //569/0BC98EB88383/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:48.921: //575/0E76FAA68398/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE6640-B5F
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=ba3466f3e5;epid=373B149707
CSEQ: 101 INVITE
CALL-ID: E7748BA-A2B011E5-839E8842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK4C46C
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:48.921: //575/0E76FAA68398/CCAPI/cc_api_event_indication:
Event=98, Call Id=575
Content-Length: 0
Dec 15 22:14:50.023: //587/13E02B6283C2/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:51.029: //573/0D9797E98391/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:14:51.933: //579/1044190283A6/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CE720E-112A
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=901eeea1c;epid=373B149707
CSEQ: 101 INVITE
CALL-ID: 10446716-A2B011E5-83AC8842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK4E252D
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:14:51.933: //579/1044190283A6/CCAPI/cc_api_event_indication:
Event=98, Call Id=579
Content-Length: 0
Dec 15 22:14:53.051: //589/14C5F86183C9/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;epid=373B149707
CSEQ: 101 CANCEL
CONTENT-LENGTH: 0
Dec 15 22:14:53.847: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
Dec 15 22:14:53.881: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+1INTERNALCALLERPHONE@MYPUBLICIP:5060;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 2 ACK
User-Agent: T7100/3.0
Content-Length: 0
Dec 15 22:14:53.881: //562/090D2D29836E/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x1DE1F444, Tag=0x0, Call Id=562,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)SIP/2.0 200 OK
CSEQ: 101 CANCEL
CONTENT-LENGTH: 0
Dec 15 22:14:54.833: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
Dec 15 22:14:54.993: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Dec 15 22:14:55.741: //582/1212223283B4/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x1DE1F444, Tag=0x0, Call Id=582,
Call Disconnect Event Sent
Dec 15 22:14:55.741: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Dec 15 22:14:55.741: :cc_free_feature_vsa freeing 200D2858
Dec 15 22:14:55.741: vsacount in free is 19
Dec 15 22:14:55.905: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Dec 15 22:14:56.871: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
Dec 15 22:14:57.059: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:+1INTERNALCALLERPHONE@CISCISBCPRIVATEIP;user=phone SIP/2.0
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com;user=phone>;tag=9d3a6166a;epid=373B149707
CSEQ: 673638 CANCEL
CALL-ID: 55e2f7fb-eb6d-42d4-ad9a-9dd45d384d32
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP MEDIATION1IP:50727;branch=z9hG4bK97201a49
CONTENT-LENGTH: 0
Reason: Q.850;cause=16
Dec 15 22:14:57.695: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
Dec 15 22:15:20.757: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:CISCISBCPRIVATEIP SIP/2.0
FROM: <sip:hestia-l1.olympus.local:5060;transport=Tcp;ms-opaque=bdf9c42b0b54f3d9>;epid=373B149707;tag=e7d08cbbe0
TO: <sip:CISCISBCPRIVATEIP>
CSEQ: 673644 OPTIONS
CALL-ID: 2682600121274e989d34251c40cc59f3
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP MEDIATION1IP:50782;branch=z9hG4bK1ac593fd
CONTENT-LENGTH: 0
Dec 15 22:15:20.757: //604/2A04CF508401/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
Dec 15 22:15:20.757: //604/2A04CF508401/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config: MF: Dial-peer is absent..
Dec 15 22:15:20.759: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/TCP MEDIATION1IP:50782;branch=z9hG4bK1ac593fd
From: <sip:hestia-l1.olympus.local:5060;transport=Tcp;ms-opaque=bdf9c42b0b54f3d9>;epid=373B149707;tag=e7d08cbbe0
To: <sip:CISCISBCPRIVATEIP>;tag=CF1AD2-2254
Date: Tue, 15 Dec 2015 22:15:20 GMT
Call-ID: 2682600121274e989d34251c40cc59f3
CSeq: 673644 OPTIONS
Accept: application/sdp
Content-Length: 363
v=0
o=CiscoSystemsSIP-GW-UserAgent 7171 6697 IN IP4 CISCISBCPRIVATEIP
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Dec 15 22:15:24.647: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+1INTERNALCALLERPHONE@MYPUBLICIP:5060;user=phone SIP/2.0
Via: SIP/2.0/TCP INTELEPEERSIGNALING:5060;branch=z9hG4bK-002-92b1fbb-4625e0eb
Max-Forwards: 17
From: "Caller Name" <sip:+1EXTERNALCALLERPHONE@INTELEPEERSIGNALING:5060;user=phone>;tag=92b1fbb0a010100
Call-ID: 1-92b1fbb0a010100.b7108f2@INTELEPEERSIGNALING
CSeq: 2 INVITE
Contact: <sip:+1EXTERNALCALLERPHONE@INTELEPEERSIGNALING:5060;transport=tcp;user=phone>
Allow: ACK, BYE, CANCEL, INVITE, OPTIONS, PRACK
Supported: 100rel
Content-Length: 221
v=0
o=- 1450218575 1450218576 IN IP4 INTELEPEERMEDIA
s=IGW
c=IN IP4 INTELEPEERMEDIA
t=0 0
m=audio 14880 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
a=maxptime:20
Dec 15 22:15:24.647: //-1/2C5660A38402/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
SIP: (605) Attribute mid, level 1 instance 1 not found.
Dec 15 22:15:24.647: //605/2C5660A38402/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
Dec 15 22:15:24.647: //605/2C5660A38402/SIP/Error/sipSPI_ipip_update_call_entry:
Dec 15 22:15:24.647: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count: Unable to set CHANNEL_COUNT for callid 605
Dec 15 22:15:24.647: //605/2C5660A38402/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo: Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
Dec 15 22:15:24.647: //605/2C5660A38402/SIP/Error/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
Dec 15 22:15:24.647: //605/2C5660A38402/SIP/Error/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
Dec 15 22:15:24.647: //-1/2C5660A38402/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Dec 15 22:15:24.647: //-1/2C5660A38402/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=605
Dec 15 22:15:24.647: //-1/2C5660A38402/CCAPI/ccCheckClipClir:
Dec 15 22:15:24.647: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Dec 15 22:15:24.647: :cc_get_feature_vsa malloc success
Dec 15 22:15:24.647: cc_get_feature_vsa count is 1
Dec 15 22:15:24.647: :FEATURE_VSA attributes are: feature_name:0,feature_time:537734112,feature_id:166
Dec 15 22:15:24.647: //605/2C5660A38402/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Dec 15 22:15:24.647: //605/2C5660A38402/CCAPI/cc_process_call_setup_ind:
Event=0x1AE16268
Dec 15 22:15:24.647: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Dec 15 22:15:24.647: //605/2C5660A38402/CCAPI/ccCallSetContext:
Context=0x20313DC4
>>>>CCAPI handed cid 605 with tag 100 to app "_ManagedAppProcess_Default"
Dec 15 22:15:24.647: //605/2C5660A38402/CCAPI/ccCallProceeding:
Dec 15 22:15:24.647: //605/2C5660A38402/CCAPI/ccCallSetupRequest:
Dec 15 22:15:24.647: //605/2C5660A38402/CCAPI/ccCheckClipClir:
Guid=2C5660A3-A2B0-11E5-8402-88420441C971, Outgoing Dial-peer=300
Dec 15 22:15:24.647: //605/2C5660A38402/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Dec 15 22:15:24.647: //605/2C5660A38402/CCAPI/ccIFCallSetupRequestPrivate:
Dec 15 22:15:24.647: cc_get_feature_vsa count is 2
Dec 15 22:15:24.647: :FEATURE_VSA attributes are: feature_name:0,feature_time:537734336,feature_id:167
Dec 15 22:15:24.647: //606/2C5660A38402/SIP/Error/ccsip_ipip_media_forking_read_from_TDContainer: MF: Unable to read data from TD Container..
Dec 15 22:15:24.647: //606/2C5660A38402/SIP/Error/ccsip_ipip_media_forking_forked_leg_config: MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
Dec 15 22:15:24.647: //606/2C5660A38402/CCAPI/ccIFCallSetupRequestPrivate:
Dec 15 22:15:24.647: //606/2C5660A38402/CCAPI/ccCallSetContext:
Context=0x203151C8
Dec 15 22:15:24.647: //605/2C5660A38402/CCAPI/ccSaveDialpeerTag:
Dec 15 22:15:24.647: //606/2C5660A38402/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
Dec 15 22:15:24.647: //606/2C5660A38402/SIP/Error/sip_iwf_sip_copy_channelInfo_to_sdp: We are either escalating, orno stream found for this m-line index:1
Dec 15 22:15:24.647: //606/2C5660A38402/CCAPI/cc_api_event_indication:
Event=184, Call Id=606
Dec 15 22:15:24.647: //605/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Dec 15 22:15:24.647: cc_api_get_xcode_stream : 4802
Dec 15 22:15:24.647: //606/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Dec 15 22:15:24.649: //606/2C5660A38402/CCAPI/cc_api_call_proceeding:
SIP: (606) Group (a= group line) attribute, level 65535 instance 1 not found.
Dec 15 22:15:24.649: //606/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Dec 15 22:15:24.649: cc_api_get_xcode_stream : 4802
Dec 15 22:15:24.649: //605/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Dec 15 22:15:24.649: //605/2C5660A38402/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 15 Dec 2015 22:15:24 GMT
CSeq: 2 INVITE
Content-Length: 0
Dec 15 22:15:24.649: //606/2C5660A38402/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK5B598
From: "Caller Name" <sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF2A06-BF6
Call-ID: 2C56AEB7-A2B011E5-84088842-441C971@SIPDOMIN.com
Min-SE: 180
Cisco-Guid: 0743858339-2729447909-2214758466-0071420273
CSeq: 101 INVITE
Timestamp: 1450217724
Expires: 180
Max-Forwards: 16
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 3816 1440 IN IP4 CISCISBCPRIVATEIP
s=SIP Call
t=0 0
m=audio 31270 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF2A06-BF6
CSEQ: 101 INVITE
CALL-ID: 2C56AEB7-A2B011E5-84088842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK5B598
CONTENT-LENGTH: 0
TIMESTAMP: 1450217724
Dec 15 22:15:24.777: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: <sip:hestia-l2.olympus.local:5060;transport=Tcp;ms-opaque=064169c00ed44fc0>;epid=14576FA8A7;tag=a258862b7
CSEQ: 665436 OPTIONS
CALL-ID: c3467e4faa924d10965c77452d719953
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP MEDIATION2IP:51201;branch=z9hG4bK9ad27844
CONTACT: <sip:hestia-l2.olympus.local:5060;transport=Tcp;maddr=MEDIATION2IP>
CONTENT-LENGTH: 0
Dec 15 22:15:24.777: //607/2C6A36188409/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
Dec 15 22:15:24.777: //607/2C6A36188409/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config: MF: Dial-peer is absent..
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/TCP MEDIATION2IP:51201;branch=z9hG4bK9ad27844
From: <sip:hestia-l2.olympus.local:5060;transport=Tcp;ms-opaque=064169c00ed44fc0>;epid=14576FA8A7;tag=a258862b7
To: <sip:CISCISBCPRIVATEIP>;tag=CF2A86-2247
Call-ID: c3467e4faa924d10965c77452d719953
CSeq: 665436 OPTIONS
Content-Length: 363
v=0
o=CiscoSystemsSIP-GW-UserAgent 1436 1262 IN IP4 CISCISBCPRIVATEIP
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Dec 15 22:15:25.883: //606/2C5660A38402/SIP/Msg/ccsipDisplayMsg:
Received:
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=9bc08a4b3f;epid=373B149707
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:25.883: //606/2C5660A38402/CCAPI/cc_api_event_indication:
Event=98, Call Id=606
Dec 15 22:15:25.883: //606/2C5660A38402/CCAPI/cc_api_call_cut_progress:
Cause Value=0
Dec 15 22:15:25.883: //605/2C5660A38402/CCAPI/ccCallCutProgress:
Dec 15 22:15:25.883: //605/2C5660A38402/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+1INTERNALCALLERPHONE@MYPUBLICIP:5060;user=phone>;tag=CF2ED8-2137
CSeq: 2 INVITE
Content-Length: 0
Dec 15 22:15:26.139: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com;user=phone>;epid=373B149707;tag=7d9c3e2f9a
CSEQ: 673645 INVITE
CALL-ID: 44eec6c1-4252-4cf5-9cf2-ea01eb3362fc
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP MEDIATION1IP:50741;branch=z9hG4bK9146425d
CONTENT-LENGTH: 330
SUPPORTED: 100rel
ALLOW: ACK
v=0
o=- 49171 1 IN IP4 MEDIATION1IP
s=session
b=CT:1000
t=0 0
m=audio 54834 RTP/AVP 97 101 13 0 8
a=rtcp:54835
a=label:Audio
a=sendrecv
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=ptime:20
Dec 15 22:15:26.141: //-1/2D3A0A7D840A/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
SIP: (608) Attribute mid, level 1 instance 1 not found.
Dec 15 22:15:26.141: //608/2D3A0A7D840A/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
Dec 15 22:15:26.141: //608/2D3A0A7D840A/SIP/Error/sipSPI_ipip_update_call_entry:
Dec 15 22:15:26.141: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count: Unable to set CHANNEL_COUNT for callid 608
Dec 15 22:15:26.141: //608/2D3A0A7D840A/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo: Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
Dec 15 22:15:26.141: //608/2D3A0A7D840A/SIP/Error/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
Dec 15 22:15:26.141: //608/2D3A0A7D840A/SIP/Error/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
Dec 15 22:15:26.141: //-1/2D3A0A7D840A/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Dec 15 22:15:26.141: //-1/2D3A0A7D840A/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=608
Dec 15 22:15:26.141: //-1/2D3A0A7D840A/CCAPI/ccCheckClipClir:
Dec 15 22:15:26.141: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Dec 15 22:15:26.141: :cc_get_feature_vsa malloc success
Dec 15 22:15:26.141: cc_get_feature_vsa count is 3
Dec 15 22:15:26.141: :FEATURE_VSA attributes are: feature_name:0,feature_time:537735680,feature_id:168
Dec 15 22:15:26.141: //608/2D3A0A7D840A/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Dec 15 22:15:26.141: //608/2D3A0A7D840A/CCAPI/cc_process_call_setup_ind:
Event=0x1AE16268
Dec 15 22:15:26.141: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Dec 15 22:15:26.141: //608/2D3A0A7D840A/CCAPI/ccCallSetContext:
Context=0x203165CC
>>>>CCAPI handed cid 608 with tag 100 to app "_ManagedAppProcess_Default"
Dec 15 22:15:26.141: //608/2D3A0A7D840A/CCAPI/ccCallProceeding:
Dec 15 22:15:26.141: //608/2D3A0A7D840A/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=300, Params=0x20317A1C, Progress Indication=NULL(0)
Dec 15 22:15:26.141: //608/2D3A0A7D840A/CCAPI/ccCheckClipClir:
Guid=2D3A0A7D-A2B0-11E5-840A-88420441C971, Outgoing Dial-peer=300
Dec 15 22:15:26.141: //608/2D3A0A7D840A/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Dec 15 22:15:26.141: //608/2D3A0A7D840A/CCAPI/ccIFCallSetupRequestPrivate:
Dec 15 22:15:26.141: cc_get_feature_vsa count is 4
Dec 15 22:15:26.141: :FEATURE_VSA attributes are: feature_name:0,feature_time:537735456,feature_id:169
Dec 15 22:15:26.141: //609/2D3A0A7D840A/SIP/Error/ccsip_ipip_media_forking_read_from_TDContainer: MF: Unable to read data from TD Container..
Dec 15 22:15:26.141: //609/2D3A0A7D840A/SIP/Error/ccsip_ipip_media_forking_forked_leg_config: MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
Dec 15 22:15:26.141: //609/2D3A0A7D840A/CCAPI/ccIFCallSetupRequestPrivate:
Dec 15 22:15:26.141: //609/2D3A0A7D840A/CCAPI/ccCallSetContext:
Context=0x203179D0
Dec 15 22:15:26.141: //608/2D3A0A7D840A/CCAPI/ccSaveDialpeerTag:
Dec 15 22:15:26.141: //609/2D3A0A7D840A/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
Dec 15 22:15:26.141: //609/2D3A0A7D840A/SIP/Error/sip_iwf_sip_copy_channelInfo_to_sdp: We are either escalating, orno stream found for this m-line index:1
Dec 15 22:15:26.141: //609/2D3A0A7D840A/CCAPI/cc_api_event_indication:
Event=184, Call Id=609
Dec 15 22:15:26.141: //608/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Dec 15 22:15:26.141: cc_api_get_xcode_stream : 4802
Dec 15 22:15:26.141: //609/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Dec 15 22:15:26.141: //609/2D3A0A7D840A/CCAPI/cc_api_call_proceeding:
SIP: (609) Group (a= group line) attribute, level 65535 instance 1 not found.
Dec 15 22:15:26.141: //608/2D3A0A7D840A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP MEDIATION1IP:50741;branch=z9hG4bK9146425d
From: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com;user=phone>;epid=373B149707;tag=7d9c3e2f9a
Date: Tue, 15 Dec 2015 22:15:26 GMT
Call-ID: 44eec6c1-4252-4cf5-9cf2-ea01eb3362fc
CSeq: 673645 INVITE
Content-Length: 0
Dec 15 22:15:26.141: //609/2D3A0A7D840A/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK5C1B49
From: "Caller Name" <sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF2FDA-216E
Call-ID: 2D3A5891-A2B011E5-84108842-441C971@SIPDOMIN.com
Min-SE: 180
Cisco-Guid: 0758778493-2729447909-2215282754-0071420273
CSeq: 101 INVITE
Timestamp: 1450217726
Expires: 180
Max-Forwards: 69
Content-Length: 240
v=0
o=CiscoSystemsSIP-GW-UserAgent 341 2591 IN IP4 CISCISBCPRIVATEIP
s=SIP Call
t=0 0
m=audio 26364 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Dec 15 22:15:26.143: //609/2D3A0A7D840A/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF2FDA-216E
CSEQ: 101 INVITE
CALL-ID: 2D3A5891-A2B011E5-84108842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK5C1B49
CONTENT-LENGTH: 0
TIMESTAMP: 1450217726
Dec 15 22:15:27.379: //609/2D3A0A7D840A/SIP/Msg/ccsipDisplayMsg:
Received:
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=a490a142f4;epid=373B149707
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:27.379: //609/2D3A0A7D840A/CCAPI/cc_api_event_indication:
Event=98, Call Id=609
Dec 15 22:15:27.379: //609/2D3A0A7D840A/CCAPI/cc_api_call_cut_progress:
Cause Value=0
Dec 15 22:15:27.379: //608/2D3A0A7D840A/CCAPI/ccCallCutProgress:
Dec 15 22:15:27.379: //608/2D3A0A7D840A/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+1INTERNALCALLERPHONE@CISCISBCPRIVATEIP;user=phone>;tag=CF34B0-894
CSeq: 673645 INVITE
Content-Length: 0
Dec 15 22:15:27.579: //606/2C5660A38402/SIP/Msg/ccsipDisplayMsg:
Received:
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:27.579: //606/2C5660A38402/CCAPI/cc_api_event_indication:
Dec 15 22:15:27.579: //606/2C5660A38402/CCAPI/cc_api_call_cut_progress:
Cause Value=0
Dec 15 22:15:27.579: //605/2C5660A38402/CCAPI/ccCallCutProgress:
Dec 15 22:15:27.579: //605/2C5660A38402/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 2 INVITE
Remote-Party-ID: <
Dec 15 22:15:27.653: //611/2E20C04B8411/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF35C2-AC
CSEQ: 101 INVITE
CALL-ID: 2E210E5F-A2B011E5-84178842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK5D222B
CONTENT-LENGTH: 0
TIMESTAMP: 1450217727
Dec 15 22:15:28.893: //611/2E20C04B8411/SIP/Msg/ccsipDisplayMsg:
Received:
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=7f222857;epid=373B149707
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:28.893: //611/2E20C04B8411/CCAPI/cc_api_event_indication:
Event=98, Call Id=611
Dec 15 22:15:28.893: //611/2E20C04B8411/CCAPI/cc_api_call_cut_progress:
Cause Value=0
Dec 15 22:15:28.893: //610/2E20C04B8411/CCAPI/ccCallCutProgress:
Dec 15 22:15:29.159: //613/2F068D498418/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF3BA4-14E5
CSEQ: 101 INVITE
CALL-ID: 2F06DB5D-A2B011E5-841E8842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK5E2663
CONTENT-LENGTH: 0
TIMESTAMP: 1450217729
Content-Length: 0
Dec 15 22:15:30.863: //615/2FEC0A2F841F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF4184-19B3
CSEQ: 101 INVITE
CALL-ID: 2FEC5843-A2B011E5-84258842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK5F9BA
CONTENT-LENGTH: 0
TIMESTAMP: 1450217730
Dec 15 22:15:31.909: //615/2FEC0A2F841F/SIP/Msg/ccsipDisplayMsg:
Received:
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=81e6ead473;epid=373B149707
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:31.909: //615/2FEC0A2F841F/CCAPI/cc_api_event_indication:
Event=98, Call Id=615
Dec 15 22:15:31.909: //615/2FEC0A2F841F/CCAPI/cc_api_call_cut_progress:
Cause Value=0
Dec 15 22:15:31.909: //614/2FEC0A2F841F/CCAPI/ccCallCutProgress:
Content-Length: 0
Content-Length: 0
Dec 15 22:15:33.687: //619/31B97737842D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF4D52-920
CSEQ: 101 INVITE
CALL-ID: 31B97737-A2B011E5-84338842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK618B1
CONTENT-LENGTH: 0
TIMESTAMP: 1450217733
Dec 15 22:15:33.887: //611/2E20C04B8411/SIP/Msg/ccsipDisplayMsg:
Received:
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:33.887: //611/2E20C04B8411/CCAPI/cc_api_event_indication:
Content-Length: 0
Dec 15 22:15:34.945: //619/31B97737842D/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:15:36.469: //621/32A1B56E8434/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:15:36.927: //623/338906CB843B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF5932-64C
CSEQ: 101 INVITE
CALL-ID: 338954DF-A2B011E5-84418842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK6314C7
CONTENT-LENGTH: 0
TIMESTAMP: 1450217736
Dec 15 22:15:36.927: //613/2F068D498418/SIP/Msg/ccsipDisplayMsg:
Received:
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=82f6e454b;epid=373B149707
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:36.927: //613/2F068D498418/CCAPI/cc_api_event_indication:
Event=98, Call Id=613
Content-Length: 0
Dec 15 22:15:37.989: //623/338906CB843B/SIP/Msg/ccsipDisplayMsg:
Received:
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=32149d9223;epid=373B149707
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:37.989: //623/338906CB843B/CCAPI/cc_api_event_indication:
Event=98, Call Id=623
Content-Length: 0
Dec 15 22:15:39.059: //606/2C5660A38402/SIP/Msg/ccsipDisplayMsg:
Received:
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:39.059: //606/2C5660A38402/CCAPI/cc_api_event_indication:
Content-Length: 0
Dec 15 22:15:39.973: //627/355A1D5C8449/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF651A-1134
CSEQ: 101 INVITE
CALL-ID: 355A6B70-A2B011E5-844F8842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK651C6C
CONTENT-LENGTH: 0
TIMESTAMP: 1450217739
Dec 15 22:15:39.973: //619/31B97737842D/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Dec 15 22:15:41.027: //627/355A1D5C8449/SIP/Msg/ccsipDisplayMsg:
Received:
TO: <sip:+1INTERNALCALLERPHONE@MEDIATION1IP>;tag=d49e1c8ecc;epid=373B149707
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:41.027: //627/355A1D5C8449/CCAPI/cc_api_event_indication:
Event=98, Call Id=627
Content-Length: 0
Dec 15 22:15:41.901: //613/2F068D498418/SIP/Msg/ccsipDisplayMsg:
Received:
CSEQ: 101 INVITE
CONTENT-LENGTH: 0
ALLOW: CANCEL
ALLOW: BYE
ALLOW: UPDATE
ALLOW: PRACK
Dec 15 22:15:41.901: //613/2F068D498418/CCAPI/cc_api_event_indication:
Content-Length: 0
Dec 15 22:15:43.005: //631/3728C2B48457/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com>;tag=CF70F2-18E4
CSEQ: 101 INVITE
CALL-ID: 372910C8-A2B011E5-845D8842-441C971@SIPDOMIN.com
VIA: SIP/2.0/TCP CISCISBCPRIVATEIP:5060;branch=z9hG4bK6731C
CONTENT-LENGTH: 0
TIMESTAMP: 1450217742
Dec 15 22:15:43.005: //621/32A1B56E8434/SIP/Msg/ccsipDisplayMsg:
Received:
Dec 15 22:15:43.801: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
Dec 15 22:15:43.955: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: "Caller Name"<sip:+1EXTERNALCALLERPHONE@SIPDOMIN.com;user=phone>;tag=abcff9f92d;epid=373B149707
CSEQ: 673647 CANCEL
CALL-ID: 6e9a3594-eb18-4db9-80b0-fac9f3f19626
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP MEDIATION1IP:50738;branch=z9hG4bKdca77ba
CONTENT-LENGTH: 0
Dec 15 22:15:44.791: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
Dec 15 22:15:44.985: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Dec 15 22:15:45.715: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Dec 15 22:15:45.715: :cc_free_feature_vsa freeing 200D1DD8
Dec 15 22:15:45.715: vsacount in free is 0
Dec 15 22:16:17.123: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:CHI43GHDS0002W80002@MYPUBLICIP:5060 SIP/2.0
Max-Forwards: 70
From: CHI43GHDS0002W80002 <sip:CHI43GHDS0002W80002@INTELEPEERSIGNALING:5060>;tag=92b289115010100
To: CHI43GHDS0002W80002 <sip:CHI43GHDS0002W80002@MYPUBLICIP:5060>
Call-ID: 1-T7100.660666373927665920@INTELEPEERSIGNALING
CSeq: 980 OPTIONS
Contact: CHI43GHDS0002W80002 <sip:CHI43GHDS0002W80002@INTELEPEERSIGNALING:5060>
Content-Length: 0
Dec 15 22:16:17.123: //634/4B9D94C58465/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
Dec 15 22:16:17.123: //634/4B9D94C58465/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config: MF: Dial-peer is absent..
Sent:
SIP/2.0 200 OK
To: CHI43GHDS0002W80002 <sip:CHI43GHDS0002W80002@MYPUBLICIP:5060>;tag=CFF700-1040
Date: Tue, 15 Dec 2015 22:16:17 GMT
CSeq: 980 OPTIONS
Content-Length: 362
v=0
o=CiscoSystemsSIP-GW-UserAgent 955 1155 IN IP4 MYPUBLICIP
s=SIP Call
c=IN IP4 MYPUBLICIP
t=0 0
c=IN IP4 MYPUBLICIP
m=image 0 udptl t38
c=IN IP4 MYPUBLICIP
a=T38FaxVersion:0
SBC-R3900-A#
SBC-R3900-A#
Dec 15 22:16:21.997: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
FROM: <sip:hestia-l1.olympus.local:5060;transport=Tcp;ms-opaque=bdf9c42b0b54f3d9>;epid=373B149707;tag=cd5b6ee211
CSEQ: 673661 OPTIONS
Thanks is this debug attached is for inbound or outbound call?  can collect inbound and outbound debug in separate notepad and please mentioned calling and called party number.
Br,
nadeem
This is for an inbound call
From the wireshark it looks like the incoming call spawns an outgoing call which spawns and incoming call.  Each of these calls shows as canceled
it is very strange.
Calling number is 860841xxxx
called number is 860207xxxx
I cant make an outbound call until I get back to office tomorrow.
Ideally  it should contain numeric digit in from and to header or SIP message it carrying overdecadic digits. It just matches the  dial-peer as the destination pattern you set it to "+" which can be match with ANI or DNIS.
Please check on the lync server is there any setting or something which can be set to send numeric E.164 so that voice routing can be happened and call should work.
Br,
Nadeem Ahmed
I just removed the numbers are to post it.
It it did say +1860841xxxx for caller and +1860201xxxx for called.
got it! Meanwhile enable the prack which is disabled right now on Cisco Gateway
Global level:
voice service voip
sip
rel1xx require 100rel
Is it possible to post the debug in the notepad for the inbound fails call.
I got hit with other failures here that I had to work on before this.
Although right now it is making in and outbound calls.  I have not been able to do any further testing.
I just wanted to thank you for you help.
