Unable to Dial International Calls from the USA
smh1218
I am having difficulties getting International Calls to go through. Does anyone have any clue to what would be preventing me from making those calls?
RtR Config:
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-24
vlan internal allocation policy ascending
isdn switch-type primary-ni
voice-port 0/2/0:23
bearer-cap Speech
dial-peer cor custom
name internal
name local
name domestic
name international
name 900
name 976
dial-peer cor list call-international
member international
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer voice 6 pots
description Outgoing Calls
destination-pattern 9T
port 0/2/0:23
dial-peer voice 5 pots
description International
destination-pattern 9011T
port 0/2/0:23
forward-digits 15
2 Accepted Solutions
paolo bevilacqua
Hi, for your DP 5, the proper config config is wihtout any forward-digits command, and prefix 011 instead.
Another little know technique is:
destination-pattern 9[0][0][1].......T
this way, no prefix command is needed.
Hope this elps, please rate post if it does!
telcos and they're requests hehe
weird thing, i've configured that but if i strip the 011 i at least set the call as international but if that's what the telco expects let's give them that
drop the prefix command from the dial-peer and if you're using CUCM change the type under the GW or endpoint config to send them unknown and try again
javalenc
if this helps, please rate
java
20 Replies 20
paolo bevilacqua
p.bevilacqua -
Thank you so much for the fast response. If I am reading your reply correctly my DP 5 should look like this?
port 0/2/0:23
prefix 011
Yes. Only, it is always better to place at least 6-8 dots before the T to enforce a reasonable minimum lenght in the number.
Hey Paolo, i've never thought of using a couple of dots in the international calla dial-peer but guess you're right.
Some extra dots before the T won't hurt =), at least a couple of them for the country code
also as a little extra to your info, Steven when configuring a dial-peer or a route pattern for international calls there is really no way to know how many digits a user is going to dial and since the dial plans in the world are very different configuring a hard number of digits would mean that only countries to which that max N numbers make the whole phone number would be reachable.
in your initial scenario a call to a country in which i need 16 digits to call would fail.
javalenc
java
Yes, in fact an even better DP for international would be:
destination-pattern 9011[2-9].....T
I personally like to enforce dialplans in the gateway to minimize misdialed calls.
gogasca
Level 10
Level 10
After hcanging the dial-peer check if you are in fact sending a q.931 setup message or not by debugging debug isdn q931
You may try to tweak the numplan or num type for isdn called party
The international call is still failing, here is the debug of the ISDN call as requested. I get a fast busy when I call international...
Apr 7 21:59:48.001: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 9185911093
Apr 7 21:59:48.001: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x1 0x1, Called num 011972777870200
Apr 7 21:59:48.005: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8 callref = 0x04D6
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98396
Exclusive, Channel 22
Progress Ind i = 0x8183 - Origination address is non-ISDN
Display i = 'Scott Gund'
Calling Party Number i = 0x2180, '9185911093'
Plan:ISDN, Type:National
Called Party Number i = 0x91, '011972777870200'
Plan:ISDN, Type:International
Apr 7 21:59:48.057: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x84D6
Apr 7 21:59:48.057: ISDN Se0/2/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x84D6
Cause i = 0x829F - Normal, unspecified
Progress Ind i = 0x8488 - In-band info or appropriate now available
Apr 7 21:59:50.705: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x04D6
Cause i = 0x8090 - Normal call clearing
Apr 7 21:59:50.721: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x84D6
Apr 7 21:59:50.725: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x04D6do
Apr 7 21:59:57.653: %ISDN-6-DISCONNECT: Interface Serial0/2/0:22 disconnected from 6250662 , call lasted 173 seconds
Apr 7 21:59:57.657: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x04D5
Apr 7 21:59:57.681: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x84D5
Apr 7 21:59:57.685: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x04D5term no mon
Where is that you configured type international ? in the CM, or do you have a translation profile or isdn map address perhaps, please remove that, is not supposed to be there.
It is configured in the CM. Do I need to set it to "unknown"?
do you know what is your telco expecting for international calls??
what digits are they expecting?
what numbering plan?
this way you can match those requirements
javalenc
java
I really appreciate all the help .... I just spoke to the Telco and they are telling me they needing me to set the switch type to UNKNOWN, and that I need to strip off the 011 before sending them the digits.
That doesnt make sense to me, how will the telco's dms switch no what to do with the call if I strip the 011 off?
Yes please.
javalenc
java
The logic of not needing prefix when type is international makes perfects sense.
Then you have at least 10 different places in CM and router where you could play with numbers and plan/type, all of which again do make sense if you know what are you doing.
But at the end of the day I understand that with all these things perfectly under control for the experienced, someone at the first installation (and 2nd, 3rd possibly) will get lost in no time.
