Unable to forward call to RDP
rahmathalipn
Hi Legends ,
We are unable to forward call from HUNT GROUP  when none of user are not responding call is not forwarding to  user RDP profile and getting call disconnected...
SCENARIO
User A calls to ===>  CS HUNT GROUP USER B , User C , USER D ( BROADCASTING , NONE OF ATTENDING  ) ===> USER B RDP PROFILE (CALL IS DISCONNECTING )
2 Accepted Solutions
All call forwarding behavior is ignored by members of the line group when the call arrives via the hunt pilot.
java
if this helps, please rate
FOUND SOLUTION
I have added a Route pattern for Remote destination profile profile Extension after it got worked....!
Jaime Valencia
Does SNR work properly when placing a call directly to that DN?
What does the debug on the GW say about the call?
java
Hi ,
We are able to made the call to RDP profile when we dial directly to the number ... But when it was coming through the callhunt call is disconnecting after RNA Reversion Timeout not forwarding to RDP ....
As per i did googling some websites are showing this feature is not possible for call hunt.. here am going to do below scenario..
Line group > Dummy number (Revision timeout 1 sec ) forward to user number > RDP profile
Please let me know if any possiblity i can done it any other way it will more helpful for me.... :)
java
FOUND SOLUTION
