Unable to forward the Calls from IP Phone to Mobile
roopesh.n
Hi All,
We  have Using CCM 4.0 .All the Call from out side will Come to the  Reception IP Phone (Model 7940). From there We are unable to forward the  call to my mobile. From Extenson we are able to forward the Call to  mobile
Roopesh
33 Replies 33
Hi Roopesh,
From what I can see the call come from the PSTN to you and uses PLAR to dial 500
500 matches dial peeer 106 and sent to CUCM on IP address 10.10.14.11
The forwarded call comes to the router as 0.9902025093
This matches dial peer 14 and sent out on the ISDN 4/0:15
To ensure correct codecs can you try pasting the following lines into
the config
conf t
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
dial-peer voice 1 pots
description *** FOR INCOMING DIAL PEER MATCHING ***
incoming called-number .
direct-inward-dial
port 4/0:15
dial-peer voice 106 voip
destination-pattern 5..
session target ipv4:10.10.14.11
dtmf-relay h245-alphanumeric
no codec g711ulaw
voice-class codec 1
voice-class h323 1
ip qos dscp cs5 media
no vad
end
Then retry the test call
Alex
Regards, Alex. Please rate useful posts.
Thank you Very Much Alex,
I will make the Change and i Will update the same to you.
I have one more problem .
I was not able to Dial the Pri Line NO 25053500. Can you Find the above configuration and sugggest any thing wrong with this.
Roopesh
Roopesh
If 25053500 is an outbound call it needs to have a leading "0" -- IE 0.25053500 to match
dial peeer 14 and the ISDN/PRI
dial-peer voice 14 pots
destination-pattern 0T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 4/0:15
Alex
Hi Alex,
The thing Is We have Two line One is For incomming and one is for Out going
25053500 is for only incomming And now it is connected to Controller E1 like
controller E1 2/1
framing NO-CRC4
clock source internal
pri-group timeslots 1-31
description for Income
Once i Dialed this no It used lonch on Reception .
Now it is not hapening.
Alex.
Hi Roopesh,
From your config the components for ISDN/PRI 2/1:15
controller E1 2/1
framing NO-CRC4
interface Serial2/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
voice-port 2/1:15
connection plar 500
codec g711ulaw
no vad
I would change/add a couple items
controller E1 2/1
framing NO-CRC4
no clock source internal
The ISDN/PRI should be taking it clock from line not internally
I would also add a dial peer to match incoming calls from this PRI
dial-peer voice 2 pots
direct-inward-dial
port 2/1:15
Please nort that this line
(incoming called-number .)
Needs to include the "space" and the fullstop "."
Can you also confirm that the ISDN is in service and Up
show isdn status
Alex
Thanks For the replay Alex,
I will make the Changes in Gateway And i will come back to you.
Roopesh
Hi Alex,
Thank you very much .We Completed our first task successes fully .Now we are able to forward the Call to Mobiles. Thank you for your extended support.
Roopesh
Roopesh,
Glad to be of assistance.
Good to hear of success
Hi Alex ,
Our Second issue PRI line Dosent seems working after making the requsted change . But One improvment is there it is now the call is conecting but unable to here the sound from both side.
Roopesh
Roopesh,
To refresh us as what is happening
You receive a call on the ISDN/PRI 2/1:15
This should call your reception desk.
On the voice port for 2/1:15 you are using PLAR
voice-port 2/1:15
connection plar 500
So this meens all calls coming in on this PRI will route to Number 500
So there is a matching dial peer "106"
What is number 500 in the CUCM ?
Alex
Hi Alex,
If I Dailed 500 it will reach Reception(100).Now If dailed 025053500 it is connecting to reception but not able to hear.
Roopesh
Roopesh,
Can you post the latest config
Show runn
Alex
Hi Alex,
Here is the Running Configuration and ISDN Status.
Current configuration : 6792 bytes
version 12.3
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname oh-rt2
boot-start-marker
boot system flash c3745-advipservicesk9-mz.123-26.bin
boot-end-marker
logging buffered 4096 notifications
enable secret 5 $1$AgBh$dCd1NSglSXBbZXmjcdO/I.
clock timezone IST 5 30
no network-clock-participate slot 2
no network-clock-participate slot 4
voice-card 2
dspfarm
     voice-card 4
dspfarm
dsp services dspfarm
no aaa new-model
ip subnet-zero
ip cef
ip domain name
ip audit po max-events 100
voice hunt user-busy
voice rtp send-recv
voice class codec 1
--More--         !
voice class h323 1
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.10.14.11
ccm-manager config
fax interface-type fax-mail
controller E1 2/0
framing NO-CRC4
pri-group timeslots 1-24
--More--          description for BSnl
controller E1 2/1
framing NO-CRC4
controller E1 4/0
framing NO-CRC4
description For Outgoing
ip tcp synwait-time 13
interface Multilink1
bandwidth 256
ip address 172.16.16.45 255.255.255.252
ip tcp header-compression iphc-format
--More--          ppp multilink
ppp multilink group 1
ip rtp header-compression iphc-format
interface FastEthernet0/0
ip address 10.10.14.5 255.255.255.0
ip broadcast-address 10.10.14.255
ip accounting output-packets
ip nbar protocol-discovery
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.10.14.5
interface Serial0/0
description Circuit #1 initiating in India via Bharti
bandwidth 128
no ip address
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
--More--          clock rate 2000000
ppp multilink
interface FastEthernet0/1
ip address 10.10.3.8 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial0/1
description Circuit #2 initiating in India via BSNL
bandwidth 128
no ip address
no ip route-cache
no ip mroute-cache
clock rate 2000000
interface Serial0/2
description initiating in India via TATA
bandwidth 128
no ip address
encapsulation ppp
       clock rate 2000000
ppp multilink
interface Serial0/3
no ip address
shutdown
clock rate 2000000
no cdp enable
interface Serial2/0:15
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
--More--         !
interface Serial4/0:15
no ip address
encapsulation hdlc
no cdp enable
ip classless
ip route 10.10.0.0 255.255.0.0 10.10.14.1
ip route 172.18.252.0 255.255.255.192 10.10.14.1
ip http server
no ip http secure-server
logging trap errors
access-list 1 permit 10.10.3.18 log
access-list 1 deny   any
access-list 2 permit 10.10.3.18 log
access-list 2 deny   any
dialer-list 1 protocol ip permit
snmp-server community public RO 1
snmp-server community private RW 2
snmp-server location OH/BLR/
snmp-server contact
snmp-server enable traps tty
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
cptone IN
timeouts interdigit 3
connection plar 100
voice-port 1/1/1
cptone IN
connection plar 100
voice-port 2/0:15
connection plar 100
--More--         !
voice-port 2/1:15
connection plar 500
voice-port 4/0:15
connection plar 500
mgcp
mgcp call-agent 10.10.14.11 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local FastEthernet0/0
sccp
sccp ccm 10.10.14.11 priority 1
dspfarm rtp timeout 60
dial-peer cor custom
dial-peer voice 3 pots
application mgcpapp
incoming called-number 8025053.T
direct-inward-dial
dial-peer voice 4 pots
application mgcpapp
dial-peer voice 5 pots
application mgcpapp
dial-peer voice 3000 voip
destination-pattern 3...
session target ipv4:160.100.160.151
     dial-peer voice 9999 voip
destination-pattern 9T
dial-peer voice 6 pots
application mgcpapp
direct-inward-dial
port 4/0:15
dial-peer voice 101 voip
destination-pattern 7..
codec g711ulaw
no vad
  dial-peer voice 102 voip
destination-pattern 8..
codec g711ulaw
no vad
dial-peer voice 103 voip
destination-pattern 9..
codec g711ulaw
no vad
dial-peer voice 104 voip
codec g711ulaw
no vad
  dial-peer voice 105 voip
destination-pattern 6..
codec g711ulaw
no vad
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 30 pots
preference 2
destination-pattern *5T
dial-peer voice 77 pots
    preference 2
destination-pattern *7T
dial-peer voice 29 pots
preference 1
port 1/1/0
dial-peer voice 78 pots
preference 1
port 1/1/1
application mgcpapp
direct-inward-dial
description **** For Income Dial Peer***
direct-inward-dial
port 4/0:15
--More--         !
num-exp 8025053... ...
gateway
oh-rt2#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial2/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
DEACTIVATED
    Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 0
--More--         ISDN Serial2/1:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
ACTIVE
    Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
--More--         ISDN Serial4/0:15 interface
dsl 2, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
ACTIVE
    Layer 2 Status:
    Layer 3 Status:
1 Active Layer 3 Call(s)
CCB:callid=81EB, sapi=0, ces=0, B-chan=31, calltype=VOICE
    Active dsl 2 CCBs = 1
    The Free Channel Mask:  0xBFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 1
--More--             Total Allocated ISDN CCBs = 1
oh-rt2#exit
Roopesh
Roopesh,
Can you change the clocking for PRI 2/1:15
controller E1 2/1
clock source line
Also if the call is setting Ok like
ringing then answering but no speach and the call stays up.
Usually this is an IP routing/connectivity issue between the RTP
endpoints.
Can you get the IP address of the Called phone.
Can you ping (extended) this from the gateway using a source Ip address
10.10.14.5 (Your H323 binding address)
Alex
Hi Alex,
I will update you on monday.
Happy Weak end.
Roopesh
