Unable to forward the Calls from IP Phone to Mobile
roopesh.n
Hi All,
We  have Using CCM 4.0 .All the Call from out side will Come to the  Reception IP Phone (Model 7940). From there We are unable to forward the  call to my mobile. From Extenson we are able to forward the Call to  mobile
Roopesh
33 Replies 33
Hi Alex,
Sorry for the Long Delay i was sick,
Yes Alex you are exatly right .
Call is setting ok we can here the Ring also  we are able  see the call is launching in our reception phone once we pick the call  .no Speach and call is staying up untill we disconect the call .
i think called phone means from which phone iam  making the call.Called phone IP :10.10.14.35
Reception phone ip :10.10.14.24
Please find the result for Ping
oh-rt2#ping
Protocol [ip]:
Target IP address: 10.10.14.24
Repeat count [5]: 30
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 30, 100-byte ICMP Echos to 10.10.14.24, timeout is 2 seconds:
Success rate is 83 percent (25/30), round-trip min/avg/max = 1/1/4 ms
Roopesh
Roopesh,
Can you try adding :-
dial-peer voice 11 pots
description *** FOR INCOMING DIAL PEER MATCHING ***
incoming called-number .
direct-inward-dial
port 2/1:15
Retest.
Alex
Regards, Alex. Please rate useful posts.
HI Alex,
I have added the above the configuration. But it seems not working. Same issue call is setting ok but no speech.
Roopesh
Hi Alex,
Any update...
Roopesh
