Unable to login Cisco Phone agent
abeebvm
I am having uccx version 10.5 and around 8 agents. 6 agents can login and calls are getting to the agents.
Among them two of them can not login to ip phone agent.
I am getting a message "name logged into another extension, press 1 to other agent logged out " on the phone.
I have restarted following service in uccx  restart the Browser & IP Phone Agent (BIPPA) service.
But no use. Users are integrated with AD. So user id in both cucm and uccx are same.
Please provide a solution.
Habeeb
Have you tried to write the username using upper case letters?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
6 Replies 6
Please let me know
Carlo
Hi Carlo,
I have tried this. It is not working...Please change the status. Sorry it is not correct answer.
By mistake clicked on correct answer.
Abeeb
Hi Abeeb.
Sorry but I 'm not able to che the staus removing the correct status.
anyway....
Can you try to remove the agent from uccx resources and add it again?
Also verify if that agent is still logged in through real time statistics on UCCX admin page..
Let me know
Cheers
Carlo
Hi Carlo,
Thank you for reply.I will remove and check tomorrow. Also will verify the status.
I will update tomorrow.
Hi Carlo,
I have removed agents and added again. Its working. Thank you for your support
You are most welcome Abeeb.
Glad that helped.
cheers
Carlo
