08-29-2011 02:48 AM - edited 03-16-2019 06:43 AM
I’m experiencing issue with IP PHONE 7942G and 7962G, I’m unable to modify the parameters of security configuration either If unlocked, for exemple if I want to activate the access web option when I press the button 1 nothing happens and I've not the SELECT BUTTON.
My configuration is the following :
Cisco unified communication manager express 8.6
ISR 2921 voice bundle (ios : C2900-UNIVERSALK9_NPE-M), Version 15.1(4)M)
Firmware version of IP PHONE : SCCP42.9-1-1SR1S
USER-LOCAL : FRENCH
Best regards,
Ludovic GUYOMARD
09-02-2011 12:58 AM
You can enable web access from CME using:
telephony-service
service phone webAccess 1
Then reset the phone.
Here's a full list of options available on CME:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1093090
09-07-2011 01:30 AM
Thank your very much for your answer.
Best regards
Ludovic GUYOMARD
