Unable to register cisco softphone as SIP. it keep saying "Registering" but number is reflecting on screen
deepak.sin
Unable to register Cisco soft phone as SIP. it keep saying "Registering" but number is reflecting on screen.
CUCM version : 10
CCP is showing as : SIP, when checking model information.
Deepak
10 Replies 10
Brandon Pierce
Level 4
Level 4
Which softphone, CIPC or the Jabber client?  Things you need to check:
  1. Is the phone correctly inserted into CUCM?
  2. Is there a Digest User assigned?
  3. Is the DN assigned to the phone the one showing on the screen?
Hello Brandon,
1) Phone is configured as SIP ( CIPC).
2) Digest user = NONE
3) yes
Try putting the digest user in there.  Sometimes these phones don't register without the digest user, just past experience speaking.
but same profile is working on user laptop.
Is the CIPC on your laptop previously registered to another CUCM or DN?  Is the TFTP IP valid?  Can you ping the TFTP?  No license issues either right?
Apart excellent troubleshooting steps mentioned by @Brandon, take the wireshark traces from computer on which CIPC is running and share the same.
will do and let you know..soon
1) Is the CIPC on your laptop previously registered to another CUCM or DN? >> we use to do it for testin.
2) Is the TFTP IP valid? >> yes all valid.
3) Can you ping the TFTP? >> yes
4) No license issues either right? >> Enough license
Follow Vivek's advice next then.  I'm not sure if you can delete ITL files on CIPCs or not, never had to do it but that might be worth trying too.
Product Type:   Cisco IP Communicator
Device Protocol:   SIP
Real-time Device StatusRegistration: Unregistered
IPv4 Address: 199.28.139.22
Active Load ID: CIPC-8-6-2-0
Download Status: None
Registering @ User end but not getting registering in our LAB
