Unable to SSH CUCM 6.X remotely from a desktop.
bhupendrab
We have a setup where we are trying to SSH the CUCM 6.X but not able to access it.
We have checked our whole network and have enabled port 22 throughout the network.
Please suggest what may be the issue which is causing this?
Thanks !
William Bell
Could you provide more information on the error that you are receiving when you attempt to load an SSH session?
Some thoughts off the top of my head:
1. Check your local PC to see if you have a firewall program loaded that  could be blocking access.
2. Make sure your client supports SSH protocol version 2 and AES 128-bit encryption.
3. Look (or upload) a sniffer trace from the PC that is attempting the SSH session.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Jaime Valencia
Have you tried rebooting the server just in case it's some service hanging?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
