IP Telephony and Phones
Personalize banner_3
Labels
Hi guys, I wonder if any of you experts have come across this error before ?. I have a customer that is getting this alarm  3 times a day on all three call Managers in the 3 node cluster at exactly the same time.  running  CM V7.0SyslogSeverityMatchF...
keithbrandon by Community Member
  • 3434 Views
  • 2 replies
Dear All;Is there a way to change IP Phone Directory Search Criteria from Last First name display (Default) to First Last Name display.So when user press Directory Search on IP Phone and search for someone then press search softkey, the list of users...
Ayman Sheta by Community Member
  • 986 Views
  • 0 replies
I have a Cisco Router 1800 in the remote office, this router is connected to tha main office through a mpls, the remote router has connected 2 analog phone connected to fxs ports and in a public line is connected to fxo port. Actually, all external c...
Hello everyone, I am currently having an issue with my 3560s switches. what happens is that when a 7965 phone is plugged in there's no way it recognizes it (It doesn't happen all the time)  unless I do a shut/no shut after that, the phone boots up pe...
hungeduardo by Community Member
  • 730 Views
  • 1 replies
My question is regarding Compatibility with  cisco unified  communications manager 7.1 (3b) and Cisco unity Express 7.0.5.If is  yes , can I have an exemple of configuration?I find this step of  configuration but not my scenario .http://www.cisco.com...
SUNUTECH by Level 2
  • 1370 Views
  • 3 replies
I am going to upgrade to CUCM 8 very soon.  I have a few questions for the community.When upgrading from 6.1.2 to 8 are there any issues to look out for?  It looks like it should be no problem.Does it still support the 7960G phones with SCCP?It says ...
HelloI have recently installed a CME system for a customer and they are reporting the following issue:They claim that if a phone is forwarded, that phone is unable to pickup parked calls. /* Style Definitions */ table.MsoNormalTable {mso-style-na...
rebeling by Frequent Visitor
  • 536 Views
  • 1 replies
I have recently change from CCME 4.1 up to8.0 and was having an issue with a 7941 phone load.  Thought was to factory reset the unit so that it pulls the latest load form the CCME term41.default.loads.The factory reset procedure works fine but when i...
abrashic by Community Member
  • 3734 Views
  • 4 replies
