Unable to use Opus Codec with 7821 IP Phone
lpinuel
The SDP negotiation fails. It seems Opus is not available in the phone.
I am using firmware version sip78xx.11-7-1-17 which is supposed to include support for this codec.
Any help?
Luis
DEBUG> show capabilities
Show Capabilities
Device Model :CP-7821
Touch Screen : No
MediaButtons : Yes
Headset Button : Yes
Navigation Buttons : Yes
Select Buttons : Yes
Hold/Resume Button : Yes
Transfer Button : Yes
Redial Button : No
Video Mute Button : No
MenuApp Button : Yes
Messages Button : Yes
Contacts Button : No
ScreenCtrl Button : No
Number Of LineKeys : 2
Group Listen : No
Gig Ethernet : No
Background Image : No
WideBand Headset Only: No
Add On Modules : No
Intercom : Yes
Bluetooth : No
Wi-Fi : No
USB : No
SDIO Card : No
Media Audio Codec : G.711
Media Audio Codec : G.722
Media Audio Codec : G.729
Media Audio Codec : L16
Media Audio Codec : iLBC
Media Audio Codec : G.726
Kindly find the below link helpful
The phones now support the Opus audio codec, which offers an improved, higher-quality audio for voice calls. Opus is supported on Cisco Unified Communications Manager version 11.0(1) and later.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200591-OPUS-Codec-Overview.html
Hope this helps.
Rate all helpful posts.
Abhay Singh Reyal
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
I'm sorry, I'm using Asterisk instead of the  Cisco Unified Communications Manager :-(
Thanks.
Luis
So, I believe that answers your discussion. Find the data sheet helpful as well for supported codecs
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7800-series/data-sheet-c78-729488.html
And as per link share earlier, Opus is supported on Cisco Unified Communications Manager version 11.0(1) and later.
Abhay
Kindly rate all helpful posts !!!
Abhay Singh Reyal
If the new firmware supports Opus, in theory it would be usable without CUCM in the same way as the other codecs. But the phone debug command "show capabilities" does not show Opus Codec capability and the phone does not offer Opus in the SDP negotiation.
-Luis
