05-01-2020 03:18 PM
Would like to know the details of the below debug. I would like to know why we see multiple entries when there is an incoming call in our debug detail. Is there some kind error on the configuration? I just want to understand what is happening in the debug.
Below we see a debug of the 9964514493 number. But I noticed that it matches dial-peers 7 and 8 twice. Is this correct?
DIALPEER:
debug voip dialpeer detail is ON (filter is OFF)
(Incoming)
023756: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=9964514493
023757: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
023758: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=9964514493T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
023759: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
023760: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=9964514493
023761: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023762: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023763: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=4 Is Matched
(Outgoing?) Why is there multiplee matches...on the Dial Peers
023764: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=3005, Expanded String=3005, Calling Number=
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
023765: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=7 Is Matched
023766: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=8 Is Matched
023767: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/dpMatchCore:
023768: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023769: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023770: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/dpMatchCore:
023771: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023772: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023773: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=3005, Expanded String=3005, Calling Number=3005T
023774: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023775: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023776: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=3005
(Incoming)
023777: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023778: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=3005T
023779: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
023780: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=3005
023781: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023782: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023783: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=7 Is Matched
023784: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=8 Is Matched
023785: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
023786: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023787: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023788: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
023789: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
023790: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023791: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023792: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023793: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023794: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023795: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023796: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023797: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/dpMatchCore:
023798: May 1 14:09:02.492 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023799: May 1 14:09:02.492 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023800: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=9964514493, Expanded String=9964514493, Calling Number=
023801: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=4 Is Matched
023802: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023803: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023804: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023805: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023806: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023807: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023808: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023809: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
05-04-2020 09:17 AM
@towertech wrote:Would like to know the details of the below debug. I would like to know why we see multiple entries when there is an incoming call in our debug detail. Is there some kind error on the configuration?
Could you post your configuration? Just the dial peers and their dependencies if you prefer.
