Understanding QoS "Show Queueing interface X/X" command 6500
GREGORY JACKSON
Hello -- I am trying to determine if my psckets are being marked withe correct DSCP value on a 6513 Sup2t. I have put all the output below. My primary question is the traffic coming from port 2/3/23 being marked with DSCP 46?
I am using MS Lync and the phone is Ploycom CX 600:
Interface GigabitEthernet2/3/23 queueing strategy:  Weighted Round-Robin
  Port QoS is disabled globally
  Queueing on Gi2/3/23: Tx Disabled Rx Disabled
Trust boundary disabled
  Trust state: trust DSCP
  Trust state in queueing: trust COS
  Extend trust state: not trusted [COS = 0]
  Default COS is 0
    Queueing Mode In Tx direction: mode-cos
    Transmit queues [type = 1p3q8t]:
    Queue Id    Scheduling  Num of thresholds
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
    WRR bandwidth ratios:  100[queue 1]   0[queue 2]   0[queue 3]
    queue-limit ratios:    100[queue 1]   0[queue 2]   0[queue 3]   0[Pri Queue]
    queue tail-drop-thresholds
    1     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    2     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    3     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    queue random-detect-min-thresholds
    queue random-detect-max-thresholds
    WRED disabled queues:      1  2  3
    queue thresh cos-map
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
    2     1
    2     2
    2     3
    2     4
    2     5
    2     6
    2     7
    2     8
    3     1
    3     2
    3     3
    3     4
    3     5
    3     6
    3     7
    3     8
    4     1
    Queueing Mode In Rx direction: mode-cos
    Receive queues [type = 1q2t]:
       1         Standard            2
    1     100[1] 100[2]
    1     1      0 1 2 3 4 5 6 7
    1     2
  Packets dropped on Transmit:
    BPDU packets:  0
    queue thresh             dropped  [cos-map]
    1     1                       0  [0 1 2 3 4 5 6 7 ]
  Packets dropped on Receive:
    BPDU packets:  0
SWITCH# sho run int g 2/3/23
Building configuration...
Current configuration : 614 bytes
interface GigabitEthernet2/3/23
 description Dynamic_Auth_Port
 switchport
 switchport mode access
 switchport voice vlan 281
 authentication event fail action authorize vlan 801
 authentication event no-response action authorize vlan 801
 authentication host-mode multi-domain
 authentication port-control auto
 authentication periodic
 authentication timer reauthenticate server
 authentication violation replace
 mab
 no snmp trap link-status
 dot1x pae authenticator
 dot1x timeout quiet-period 10
 dot1x timeout tx-period 15
 dot1x timeout supp-timeout 31
 dot1x max-req 3
 spanning-tree portfast edge
end
SWITCH# sho int g 2/3/23
GigabitEthernet2/3/23 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 6c41.6ae9.2df6 (bia 6c41.6ae9.2df6)
  Description: Dynamic_Auth_Port
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:00:17, output never, output hang never
  Input queue: 0/2000/1/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 17000 bits/sec, 17 packets/sec
  5 minute output rate 15000 bits/sec, 9 packets/sec
     474958 packets input, 81382436 bytes, 0 no buffer
     Received 73543 broadcasts (62798 multicasts)
     0 input errors, 0 CRC, 2 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     8528364 packets output, 1450314438 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
SWITCH# sho int g 2/3/23 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Operational Dot1q Ethertype:  0x8100
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Operational Native VLAN tagging: disabled
Voice VLAN: 281 (VoIP)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Thanks.
Greg
Hi GREGORY JACKSON,
 your QoS is disabled globally, to enable it:
mls qos
mls qos map cos-dscp 0 8 16 24 34 46 48 56
 You should try the following:
 mls qos cos 5
For more info about QoS in a 6500 Series, check this link: QoS 6500.
Hope this helps.
