Unity 4.0 and PIMG Integration question
coconino1969
Hello all
Using CUCM 7.1 and Unity 4.0.
We currently have our Unity integrated with a CUCM 7.1 and an Avaya G3, the Avaya is being relocated to a different location across the WAN and we intend to use a PIMG (digital) to re-integrate the Avaya back to Unity.
Also, we only allowed two integrations on Unity.
My question is:  Will removing the Avaya integration allow us a new integration for the PIMG?
Thanks in advance
Rob Huffman
Hi there,
Yes, if you delete the existing integration you would be able to set up a
new "second" integration using the PIMG's
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guide/itmultin.html#wp1178898
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guides/itavg3dg.html
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Rob Huffman
Hi there,
Cheers!
Rob
Thank you
I appreciate the quick response.
