unity connection 2: how to set the password never to expire?
xiaoliangyue
the web logon user CUAdministrator's password expired and I had to change it. Is there a setting to let the password never expire?
palves
did you ever find the answer to this? I'm having the same issue.
thanks,
Paul
hlarriuz
Click on the following:
Users => => Edit => Password Settings => Check "Does Not Expire"
You can also create a "Authentication Rules" for the admin account and assigned under the above configuration page "password settings", "Authentication Rule".
HLL
