Unity Connection 8.6 with Exchange 2003
b_ferguson
Trying to integrate Unity Connection 8.6 with Exchange 2003.  I keep receiving this error message while testing the accts.  Only thing that I can get to work is a message relay just stating that the user has a message.
HTTP status=[440] diagnostic=[Bad response from server, HTTP code  returned: 440]  url=[https://webmail.customer.com/exchange/user@customer.com//webmail.customer.com/exchange/user@customer.com]  request=[<?xml version="1.0"?> <D:propfind xmlns:D="DAV:" xmlns:fh="urn:schemas:httpmail:"  xmlns:h="http://schemas.microsoft.com/repl/"> <D:prop> <fh:msgfolderroot/> </D:prop> </D:propfind> ] response=[<HTML><BODY>440 Login  Timeout</BODY></HTML>]
Thanks for any help.
b_ferguson
I changed this to http instead of https and now it works except when i leave a voicemail, there is no attachment, just an email stating message from (number).  Nothing is in the body of the email message.
This is actually working after all now, found out that OWA doesn't show the attachments with Exchange 2003.
What did you do to fix it Brad?
Jason
I am having same issue with Unity 9.1.1a and Exchange 2003 SP2.  Outlook works fine but OWA not showing the attachment.  Has anyone come up with a workaround such as doing "accept and relay" under Unified Messaging Accounts?  We just upgraded from Unity 7 with UM to UCXn 9.1 single inbox.  Any help is appreciated!
