Unity Connection - Deleted User from DB now unable to import from LDAP
Ayaz Khan
We are using CUCN 8.6.  I imported a user, and no matter what changes I made calls would always go to default Unity greeting.  If I used that DN for another user it worked fine.  I deleted this user and re-added him back in, issue was still present.
I then deleted the user from DB through cli using the following command;
run cuc dbquery unitydirdb SELECT ObjectId from vw_User WHERE Alias = 'ccooper'
run cuc dbquery unitydirdb EXECUTE PROCEDURE csp_UserDelete (pObjectId='3ede294c-e5fb-4713-bacd-853c6361ec87')
Now when I try to import the user from LDAP he doesn't appear.  Other new users do.  I restarted directory sync service, performed full sync.  I am going to reboot the cluster.
If anyone has encoutered this issue or has any troubleshooting steps, please let me know.
AK
Ayaz Khan
Used the following commands, it deleted the user and allowed me import user from LDAP
run sql select userid, pkid from enduser where userid = 'pjon'
run sql delete FROM enduserappservermap WHERE fkenduser='745c067f-767c-459d-b2f1-6e88bbad915e'
