IP Telephony and Phones
Labels
Resolved! vg issue with ssh
hi we have a voice gateway c3945 (ios 15.0(1)M4) used for making outside calls with cisco callmanager.it is working fine but yesterday when i tried to activate ssh on it, it stops making outgoing/incoming calls!!!!!!!!!!when i removed the ssh command...
ohassairi by Level 5
  • 1203 Views
  • 5 replies
Hi,    I'm trying to setup a CUBE to connect to a ITSP. Everything seems to be working fine but MoH. I've seen lots of problems with MMoH, but this case I'm using unicast. I'm running CUCM BE 8.6(1), I've got a SIP trunk directly from the CUCM to the...
Hi, I can't call the UC from the PSTN,but I can call the UC directly by dialing the hunt polit number I set for the UC. This is the dial-peer I set in gateway,the ip address '142.100.64.13' is my CUCM's address,I changed the ip address to my UC's add...
Jia Hao by Level 1
  • 507 Views
  • 2 replies
We just upgraded the firmware in preparation for the 10.5 upgrade except 6941 all other phone models time shows correctly on the phone. Time displayed on 6941 is UTC/GMT time. If we downgrade the firmware back to the old one time shows up correct.CUC...
balukr by Level 2
  • 1060 Views
  • 4 replies
Hiwhen user tries to login into EM services , they are getting an error as " login unsuccessful (7) unknown error " . they are successfully logged int but every this error is displayed . i have restarted EM services it was working fine for 2 days tod...
Hi All, We have install the email client application on DX650 which requires certificate for the authentication. Require certificate pushed by Apps. we installed the certificate. But when we launch the apps it shows the error message "Certificate is ...
Hi,I've configured CME 8.6 and all is working fine I can make outgoing calls and incoming on my ISDN line however, how two small issues that I can’t quite figure out.  I'm more than certain that the two issues are down to my dial plan.  The first one...
