Unity Connection Inbox - No Link?
iancarder
I need to try to pull a deleted voice mail in unity connection.  I can log into the unitypca tool, but it's missing the link to get into the inbox.  Any thoughts?
Thanks in advance,
-Ian
Jaime Valencia
Do you have it enabled in your COS??
java
if this helps, please rate
Hi Jamie,
I have 2 entries in class of service; one named "System" and the other named "Voice Mail User COS".  In the second entry, the "Allow Users to Use the Messaging Inbox and RSS Feeds" is not checked.  I assume that needs to be checked.  If so, do I need to reboot the server afterwords?
I doubt it, however just wondering why not try restoring the deleted voicemail using the Voice  interface ?
