Unity Connection problem
born.jason
Level 5
Level 5
i have a little problem with MWI. If i have new phones it doesn`t work. It works only if i enable a notification device and make a call to the voicebox. After that i can remove the notification device and it works with the phone. But it is annoying to enable on every voicemailbox this feature and disable it after that.
Any suggestions?
Best regards
Jason
born.jason
Level 5
Level 5
nobody ?
What exact version of Unity Connection are you running?
7.1
davrojas
Level 8
Level 8
Hello Jason,
Do you currently have the latest service update ?
UCSInstall_UCOS_7.1.5.33900-10.sgn.iso
If not you can go do the following shrinked link and download it:
http://bit.ly/sISdAV
Id also like to know a couple of things?
-Are you running this UC in a cluster, virtualized, or digital networking environment?
-Are you integrating it with Exchange?
Best Regards,
    -David
