01-26-2011 10:07 PM - edited 03-16-2019 03:06 AM
A client of mine has ask me if they can have a greeting which plays after the users standard greeting that say something like "To speak with the operator press zero or hold to leave a message". Using Caller Input I can configure the zero to transfer to the operator/switch, but there is no way that I can assign an additional generic greeting which tells the caller what the options are.
I have been playing around with call handlers and after the caller hears the user greeting I have been able to send the caller to a system call hander which says "To speak with the operator press zero or hold to leave a message". However the take message option records the message from the system handler as opposed to the user.
Is it possible to do this kind of thing in Unity Connection? When I call other clients that are running Zeacom or ExchangeUM I have been presented with this kind of greeting/input after the user greeting plays.
Any help or advice is appreciated! Thanks.
Solved! Go to Solution.
01-27-2011 10:43 AM
I know Unity Connection 8.0 has the post greeting recording option for users.
01-27-2011 10:43 AM
01-27-2011 02:40 PM
This has been doing my head in so thank you jhitt. The client is running version 7 so this all makes sense now. As per release notes of 8.0(2c) post greetings recording are available.
