12-02-2009 01:58 PM - edited 03-15-2019 08:38 PM
We are elimiating our current partner exchange server and will be using a new 2007 Exchange server.
Unity 4.2
Current Exchange Server - 2003
New Exchange Server - 2007
We have a single Unity server located in Location A (current partner server is in Location A) and the new parter server (Exchange 2007) will reside in Location B.
What tasks need to be completed on the Unity Server?
What tasks need to be completed on the new Exchange Server?
Any other tasks or requirements?
What is the expected downtime for this?
Any other tips?
12-02-2009 02:46 PM
I'm afraid you cannot do that, you need at least Unity 5 to support Exchange 2007 as the partner Exchange
4.2
Exchange Requirements—Message Store
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/requirements/42cusysreq.html#wp472166
5.X
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/requirements/50cusysreq.html#wp472166
Also make sure you meet this requirements:
Physical Placement and Network Infrastructure
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/design/guide/5xcudg040.html#wp1067017
Every Exchange server on which mailboxes for that Cisco Unity server are homed. If Cisco Unity is separated by a WAN from an Exchange server on which subscriber mailboxes are homed, a second Cisco Unity server must be co-located with the remote Exchange server.
Connect the Cisco Unity server and the servers that Cisco Unity relies on with a high-speed switched gigabit network with no congestion. Total MAPI response time must be less that 10 milliseconds.
The Cisco Unity server should be installed into the same Windows site as the Exchange servers it services.
Once you're on 5.X follow this instructions:
Changing the Partner Exchange Server
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcuruge050.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-02-2009 08:03 PM
Thanks.
We might be moving it to another 2003 server now. What is the process for this?
12-03-2009 07:28 AM
All the info is already available in CCO if you search for it, the name is exactly the same as the one i already posted, only version changes
