Unity wont start after DIRT restore - DOH errors?
carlnewton
Level 3
Level 3
Guys,
Ive restored a DIRT backup onto a fresh install of a unity 4 server, however - after the DIRT restore the unity services will no longer start.
The errors i get in the event log are:
Cannot create system mailbox.  The default location is missing from the DOH system configuration (Check registry) 8004010fH
DOH logon failed due to outside caller object access error: 800f040fH
Unable to log onto the DOH.  Use Syscheck to verify the account AvCsMgr is running under has the correct permissions
AvCsMgr: Component Arbiter initialize failed. Turn on diagnostics for component Arbiter to troubleshoot. Technical Details: IAvCsComponent::Initialize failed with error [0x80004005; E_FAIL]
AvCsMgr service failed to initialize the component manager
I have re-run the permissions wizard but this seems to have no effect.
Any ides on what to do next to troubleshoot?
Thanks in advance, sorry about the small font - for some reason it wont let me make it larger.
carlnewton
Level 3
Level 3
Any ideas on this guys?
Any help would be much appreciated!
I am facing the same issue.....I have installed the fresh Cisco unity 4.x Box and restore the backup through Dirt.Now AvCsMgr service is not starting.
Please help me.
Thanks & Regds,
Lalit
shalushar
Level 7
Level 7
Hi Lalit,
Please refer the below doc which explains this problem.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/products_tech_note09186a00800949dc.shtml#topic1
Hope this helps.
Tx,
Shalu
