Universal Times shown up on the Cisco Phone instead of the Local Time
basem.a.bubakr
Although the time is set correctly whether on the CME or the CUE , that the Time show on the phones is the Universal time instead of the local time ..
is there a command to specify what time to be shown on the phone screen , the local or the universal ... because I WANT  the local time to show up on the phones ...
thanks ...
Hi Basm,
I think you can try doing create cnf to update the configuration files of
phones and reset those phones to get the new configuration from CME. please
let me know if it worked ,
P.S. make sure you have applied the correct phone type by giving "type 7911"
or "type 7945" under each ephone
9 Replies 9
vasank
under telephone-service
try time-zone ?
it'll list all the time-zones that can be configured and corresponding decimal code.
Unfortunately .. I did it .. actually when I run the command Show clock on the Router or the CUE I get the local Time and it's correct ...
the problem is The time that shows up on the phone is the universal time not the local time ...
though the universal time is also correctly adjusted ,, but  I Don't want it to show up on the phone .. I want the Local Time to show up on the phone ...
thanks verybody
hi,
1. pls share the configuration of time zone that you have set on your router and the one under telephony service
2. what are the phone models showing the UTC time and your CME version
-------------------------------------------------------------->  ROUTER  <---------------------------------------------------------------------------------------------
Router#sh run | section clock
clock timezone Tripoli 2
Router#sh run | section time
time-zone 29
time-webedit
Router#sh clock
11:03:50.005 Tripoli Mon Jan 31 2011
-------------------------------------------------------------->  CUE  <----------------------------------------------------------------------------------------------------
CUE# sh run
Generating configuration:
clock timezone Africa/Tripoli
CUE# show clock
11:03:16.163 EET Mon Jan 31 2011
The Phone Models :
Cisco IP Phone :    7911  -  7945 .
Hi Basm,
Could you provide your IOS version(to check corresponding CME that you have) it could be an issue with phone firmware that you have.... otherwise the configuration on the router and cme looks fine...to me
Hi Vasanthakumar
thanks for your concern and I do appreciate that ...
actually I'm pretty sure it's well configured whether on the Router or the CUE ... the problem is why the universal time shows up not the local one on the phone ....
here's the versions :-
Router#sh ver
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 03:12 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 4 days, 1 hour, 8 minutes
System restarted at 16:22:17 Tripoli Thu Jan 27 2011
System image file is "flash:c2801-spservicesk9-mz.150-1.M3.bin"
Last reload type: Normal Reload
CUE# show version
CUE uptime is 0 weeks, 1 days, 5 hours, 13 minutes
CPU Model:                    Celeron (Coppermine)
CPU Speed (MHz):              298.908
CPU Cache (KByte):            128
BogoMIPS:                     598.15
SKU:                          Unavailable
Chassis Type:                 C2801
Chassis Serial:               FHK1436F2W2
Module Type:                  AIM
Module Serial:                FOC143224LJ
UDI Name:                     Not Available
UDI Description:              Not Available
Compact Flash:                1024MB
SDRAM (MByte):                256
CUE#
Hi Basm,
Hi vasank
Thanks for ur support ... Yes, you got the solution , repeat IP source-address and Create Cfg
and went just fine ...
little things r big things ..
thank you again .....
Good to know ur issue is resolved....
