Hi there,
I have an issue with a UC520. Basically this is the scenario: a voice hunt group is configured on the uc500 which includes a mobile number. A call comes in via ISDN BRI to the UC500 which is diverted to this hunt group but the caller id is unknown or hidden. The uc500 passes this call to the mobile number in the hunt group but the mobile user sees the call as unknown. He should see the uc500 bri number since the call orginated from it (all outgoing calls are masked with the header number of the BRI)
I want the call that is forwarded to the end user to display the uc500 bri number and not keep displaying unknown. I tried to apply a translation rule to the calling number and successfully replaced the calling number as shown below. The initial calling party is unknown, and then i change this to 22XX0233. However the end party (in this case XXX03990) still gets unknown caller.
Do you have any insight on this.
Joseph
UC_520#
UC_520#
003276: Jun 14 14:08:44.018: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x58
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Date/Time i = 0x0C060E100317
Date (dd-mm-yr) = 12-06-14
Time (hr:mnt:sec) = 16:03:23
Calling Party Number i = 0x00A3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '22580202'
Plan:ISDN, Type:National
003277: Jun 14 14:08:44.034: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Calling num 22580233
003278: Jun 14 14:08:44.038: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Called num 79203990
003279: Jun 14 14:08:44.050: ISDN BR0/1/0 **ERROR**: L3_Go: Multi nlcb DL_EST, cid 0x8032 cr 0x0 ev 0x300 ces 1
003280: Jun 14 14:08:44.050: ISDN BR0/1/0 Q931: Sending SETUP callref = 0x0032 callID = 0x8032 switch = basic-net3 interface = User
003281: Jun 14 14:08:44.050: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xD8
Channel ID i = 0x89
Exclusive, B1
003282: Jun 14 14:08:44.066: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x32
Standard = CCITT
Channel ID i = 0x82
Preferred, B2
Calling Party Number i = 0x21A3, '22XX0233'
Called Party Number i = 0xA1, 'XXX03990'
Sending Complete
003283: Jun 14 14:08:44.338: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xB2
Channel ID i = 0x8A
Exclusive, B2
translation rule applied:
voice translation rule 4
rule 3 /^$/ /22580233/
