unregistered phone and inactive line
goranr
Can you tell me, how can I make line on a phone be inactive, when the phone is in unregistered state?
Best regards
sebastiandm
When the phone is in an unregistered state you will not be able to make incoming/outgoing calls.
exactly what you want to happen??
what behavior you want to have???
java
if this helps, please rate
java
If line is active, iven if the phone is unregistered, I will be routed to that line. It is a problem. When the line is on remote site, I will stil have to configure fild under line "Unregistered internal" and "Unregistered external" and it will be OK only for one location.
Stil, I can not use abbriviated diling (4 digit preserved srst), because that 4 digit pattern will never be matched for particular phone.
Any solution for that?
