05-12-2014 11:10 AM - edited 03-16-2019 10:46 PM
We are running Unity Connection Version 8.6.2ES38.22036-38(Vitualized Environment) .
Common partition usage for Publisher which is primary is 94%, I deleted log files through RTMT but the usage still shows up as 94%.
Any ideas would be helpful.
Asad Hanif
Solved! Go to Solution.
05-12-2014 01:24 PM
The suggestion I linked was to change the high/low watermarks for the logging. That will automatically clear out the space to get down to the configured thresholds. I'd also check to make sure there are no core dumps that could be taking up a lot of space using "utils core active list" and "utils core inactive list".
05-12-2014 12:44 PM
http://docwiki.cisco.com/wiki/Unified_CM_L2_Upgrade_Disk_Space_issues#Purge_Log_Files_by_Changing_the_Log_Partition_Watermarks
05-12-2014 01:21 PM
Thanks Brian.
I already deleted files from 2012 to Feb 2014 through RTMT but that did not resolve the issue.
05-12-2014 01:24 PM
