Update Certain Phones Device Pool
Limitless1801
  We recently opened another location and moved half of the company there. We have finally installed all the services needed for this new place and I am looking for an easy way to update a bulk of phone's device pool with this location's new settings. The only thing I should be able to use as a filter is the phone's IP address since they are in a different subnet. I am running CUCM 7.1(3).
  Any suggestions?
Thanks, RG
Jaime Valencia
BAT doesn't have any option to search via IPs, assuming you configured them with their new location at device level you can query them that way.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
