06-23-2016 03:18 PM - edited 03-17-2019 07:20 AM
Good day!!
One question, I have one cluster CUCM version 11, with LDAP Sync enable, I need update in the Permissions Information, add two Groups Standard first CCM End Users and Standard CTI, I first export all user in the .txt file and in the excel change the two rows
ACCESS CONTROL GROUP 1 | ACCESS CONTROL GROUP 2 |
Standard CTI Enabled | Standard CCM End Users |
for all users, I save the file as .txt and upload in CUCM Publisher, the txt file and start the job, but in the job result show the next warning, is neccesary pause sync LDAP ?? attach job results file
Thanks for your time!!
Update Users - Custom File
Begin Time : 06/23/2016 16:51:51
Query :
Update Users in final.txt
Failure Details :
users Error Code Error Description
Warning :
LDAP Sync status is enabled.Some fields cannot be updated.
NULL(Record Number 1) 2045 PIN must contain 1-127 numeric characters.
aceb9105402a9a7ed970dcefe3327cd85122b1ee83fd7b6ac636570c116ca7c2(Record Number 1) 2045 Digest Credentials must be 31 or less characters.
NULL(Record Number 2) 2045 PIN must contain 1-127 numeric characters.
Thanks!!!
06-23-2016 04:36 PM
Try it doing the way explained in below forum.
https://supportforums.cisco.com/discussion/11023206/bulk-update-end-user-permissions-ccm7
Above is done on CUCM version 7 and you are running 11 so the column heading will change just make note of procedure.
JB
06-23-2016 04:46 PM
Also check the below links for help.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/bulk-administration-tool/110967-bat-00.html#update
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/bat/9_1_1/CUCM_BK_C271A69D_00_cucm-bulk-administration-guide-91/CUCM_BK_C271A69D_00_cucm-bulk-administration-guide-91_chapter_010010.html
In above link check section.
JB
