SIP troubleshooting - incoming and outgoing call failed (SIP/2.0 480 Temporarily Not Available)
kelvinffhan
Hi Experts,
I have a SIP trunk deployment and the connectivity are as below.
CUCM --- <SIP> --- Voice Gateway --- <SIP> --- ITSP
x.x.10.137 - Voice Gateway
x.x.10.139 - CUCM
I am hitting the error as below when making incoming call.
Received:
Via: SIP/2.0/UDP x.x.10.137:5060;branch=z9hG4bKC5E45
From: "91111111" <sip:+6591111111@10.100.10.137>;tag=B668980-D63
To: <sip:581@x.x.10.139>;tag=182~fd44d6b4-9adf-45f7-8eca-5297c5409277-23655735
Date: Fri, 10 Jun 2016 08:17:58 GMT
Call-ID: C1718729-2E2211E6-848AEFB1-D08BC45A@x.x.10.137
CSeq: 101 INVITE
Allow-Events: presence
Server: Cisco-CUCM10.5
Content-Length: 0
Then it came out the below message after I heard the engage tone in a while.
Sent:
SIP/2.0 408 Request Timeout
Via: SIP/2.0/UDP x.x.63.213:5060;branch=z9hG4bK08B219257346823cf21
From: "91111111" <sip:+1291111111@202.163.63.213>;tag=gK08036abe
To: <sip:+1111111581@220.232.33.158>;tag=B66FE04-1DCF
Date: Fri, 10 Jun 2016 09:15:16 GMT
Call-ID: 510132665_57598502@202.163.63.213
CSeq: 170762 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Reason: Q.850;cause=102
Content-Length: 0
It was hitting the CUCM as well as I can view it from my CDR report.
5 Replies 5
Deepak Mehta
Hi kelvin,
Does your SIP trunk has calling search space set for incoming calls I believe you are trying to call 581 extension on CUCM , please make sure trunk has access to that .
Also if you are maniplutaing any digits using transklation pattern etc before sending calls to ext  , trunk should have access to that.
If still no go then attach debug ccsip messages and CCM traces for failed called with calling and called numbers.thanks
Thanks Deepak,
I have configured the inbound css where included the route partition for the phone.
Translation pattern are not involved in the deployment.
kelvinffhan
Connection-reuse command resolve the incoming call.
For outgoing call, ISP has tuned some setting on their end to make it works. They didn't disclose what has changed on their side.
Thank you for updating Kelvin.
Dennis Mink
can you add some additional info to this post: the debug ccsip messages on your gateway when making a call, also add the cucm SIP trace for a call.
Please remember to rate useful posts, by clicking on the stars below.
