Upgrade 6.0.1.2000-3 to 6.0.1.2000-4
I'm trying to update the  version of CUCM 6.0.1.2000-3 to 6.0.1.2000-4.
Go to Cisco Unified  Operating System Administration -> Settings -> Version try to  switch version from Active Version (6.0.1.2000-3) to Inactive Version  (6.0.1.2000-4), after clicking the server version of the Switch goes to  reboot.
After you restart the active version does not change. Remains 6.0.1.2000-3.
In what could be the problem?
Jaime Valencia
Have you tried reinstalling the new version and then trying to switch??
When you switch what do you see as active version?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I do not understand why reinstalling the new  version, my version 6.0.1.2000-4 - MD5 matches.
After  switching the active version remains - 6.0.1.2000-3.
